Results 1 to 15 of 20
    Dec 2019
    Europe
    Default AVDI - adaptation of instrument cluster Siemens VDO Micronas new type
    I have Audi a3 8p 2004.
    how to adapt new-used cluster to ecu? Dont have immo data from old cluster because cant communicate, I can try in bench mode but dont have cable now.
    When I try to read CS, IMMO ID and power class in immoIII/IV adaptation function cant read power class and immo id, read just cs and pin. Why?
    Immo was switched off in ecu eeprom.
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    If am remember well, you must extract pin from donor dash, then reset it, and after adapt to car with car pass.... (vcds work well with this...)
  3. The Following User Says Thank You to Panathaole For This Useful Post:
    davorsule (1st October, 2022)
    Dec 2019
    Europe
    Quote Originally Posted by Panathaole View Post
    I have extracted pin from donor dash, but can't do that with vcds because it is immo challenge id system for response from server to unlock dashboard.
    Im not sure if I can virginize new-used cluster and enter old pin which I extracted from ecu? But missing power class
    Oct 2020
    Bulgaria
    Without have ori data you cant (you can but more difficult) adapt new dash
  6. The Following 2 Users Say Thank You to evgeny87 For This Useful Post:
    davorsule (1st October, 2022), immokill (11th October, 2022)
    Dec 2019
    Europe
    Quote Originally Posted by evgeny87 View Post
    Do you know way how to adapt cluster without having immo data of old cluster?
  8. #6
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    The simplest way i think is to make immo off the ecu, to start the car, and programming the keys after to cluster to stop present the immo warning....
    And free space in your pm.....
  9. The Following User Says Thank You to Panathaole For This Useful Post:
    davorsule (19th July, 2024)
  10. #7
    Dec 2019
    Europe
    Dec 2019
    Europe
    Yeah I know, I done immo off and engine starts without faults. But on the cluster have SAFE status and power windows dont work because of that (this is standard issue).
    So need to adapt cluster, I tried to enter ecu pin, ecu CS and VIN of the car but dont have power class which is important.
    AVDI gives me error when trying to extract POWER CLASS, dont know why....
  12. #9
    Dec 2019
    Europe
    I dont have key programmer with anntena
  13. #10
    Home
    dash
    VIN : WAUZZZ8P44A059147
    Immo-ID : AUX7Z0C7FNC053
    CS : 14 64 49 3E 28 C8 92
    MAC : E3 EE C9 9D
    Config : 25 01 06 22 03 11
    Status : 0E 00 00 37 7A FB
    Login : 21062
    Transponder 1 : 82 F8 65 07
    Transponder 2 : 15 D4 65 07
    ECU
    VIN WAUZZZ8P24A123573
    immo ID AUX7Z0D0FN705J
    CS E300CB73C60196
    MAC FB7906CA
    PIN 00922
    For PC post ECU flash
    Keep in mind, English is not my native language.
  14. The Following User Says Thank You to Domi For This Useful Post:
  15. #11
    Dec 2019
    Europe
    Here is ecu flash data, can you extract power class?
    This immo data is from new-donor cluster, but dont have immo data from old cluster and transponder id from keys..... just have old immo id....
    How to make adaptation with AVDI?
  16. #12
    Home
    I can't find the PC, but if the original dash also has 93c86, put it in the programmer
  17. #13
    Dec 2019
    Europe
    Quote Originally Posted by Domi View Post
    you mean that I must read 93c86 or key transponder?
  18. #14
    Home
    old dash eeprom
  19. #15
    Dec 2019
    Europe
    old dash eeprom
    I dont have programmer.....which programmer can do this?
