Results 1 to 14 of 14
    ecumix's Avatar
    Apr 2014
    Default Jaguar bcm repair after flat baterry
    Hi can someone give me advice why after repair bcm file my remote control not close car all working good but not close car ?
    jaguar xf250 2013 year
    ecumix's Avatar
    Apr 2014
    only the fuel filler closes
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Maybe bad fix
    Try update by sdd
  4. The Following User Says Thank You to drugowaz For This Useful Post:
    ecumix (3rd October, 2022)
    Mar 2018
    UK
    What you repaired ?
    Usually this happens when disconect the battery and no need repair - must do imobilisation with JLR
  6. The Following User Says Thank You to Manta1600 For This Useful Post:
    Dec 2019
    New Zeland
    need procedure immobilization and procedure battery replacement, use sdd. after procedure will work central locking
  8. The Following User Says Thank You to obdtools For This Useful Post:
  9. #6
    ecumix's Avatar
    Apr 2014
    Hi so repair was bcm front after flat battery I have only one key and I did replacement battery procedure still no results
  10. #7
    ecumix's Avatar
    Apr 2014
    Immobilize procedure I have all staff to jlr cars , immobiliser procedure ? More details need it ?
  11. #8
    Dec 2019
    New Zeland
    service function need run this procedure, after working central locking
  12. The Following User Says Thank You to obdtools For This Useful Post:
    ecumix (4th October, 2022)
  13. #9
    ecumix's Avatar
    Apr 2014
    "security immobilization" this one correct ?
  14. #10
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Far far away
    Use SDD and replace BCM and Front BCM
  15. The Following 2 Users Say Thank You to lupu_sandu For This Useful Post:
  16. #11
    ecumix's Avatar
    Apr 2014
    Thanks for advice lupu_sandu my old friend
  17. #12
    ecumix's Avatar
    Apr 2014
    So my feedback : procedure immobilization not work after that (error> target identyfikator write error) then i moved by tips lupu_sandu i replaced bcm and now its all works .
    Thank you to all the highly decorated colleagues of this forum for their help.
  18. #13
    fred77's Avatar
    Jun 2019
    Quote Originally Posted by ecumix View Post
    Maybe I've been lucky and not had to do any other work than with SDD.
    would of gone into "replace BCM option" on SDD 1st then security
    Solidarity with Ukraine
  19. The Following User Says Thank You to fred77 For This Useful Post:
    ecumix (8th October, 2022)
  20. #14
    Dec 2018
    USA
    I get the same error on immobilization, did you replace bcm on the passanger side? with used one?
