    drws3's Avatar
    Oct 2018
    ┼♣Æquilibrium┼♥
    Default Volvo v40 190HP a Denso Specialist for DPF removal Denso_VED_XX_XX_15K100
    Hello friends ,
    i have tried to remove dpf on this volvo after i do resets writte mod file
    after a month this damm car starts to do again the regenerations
    ive tried several solutions form Swiftec , some other manual solutions , ecu decoder , ive tried anything available ...
    and manual solutions from very good tuners but seems is not enough
    can somone point me to a Denso specialist who haves working solution for this ecu
    thanks a lot ,
    best regards
    Oct 2018
    disconnect differential pressure sensor, then it will no longer regenerate
    Sep 2013
    DPF off solved in this SW 32146257AA
    WinOLS5, custom files for ECU DCU
    drws3's Avatar
    Oct 2018
    ┼♣Æquilibrium┼♥
    Quote Originally Posted by nobel View Post
    done that but still keeps regenerating mister if i disconnect egt sensors the cooling fan keeps gooing
    drws3's Avatar
    Oct 2018
    ┼♣Æquilibrium┼♥
    Quote Originally Posted by pike View Post
    you have 100% functional solution ??
    Feb 2024
    Default Same problem
    Quote Originally Posted by drws3 View Post
    Hello friends ,
    thanks a lot ,
    best regards
    I have exactly the same problem, did you find a solution?
