Got it finally. First of all this bench cable is wired wrong. Couldn't get solid CAN coms to work while JBBFE and DME was hooked up. Would drop modules randomly with ident in Ista.
https://www.uhs-hardware.com/product...-bmw-cas2-cas3
The DME connector is wired straight to the OBD port Can low and Can high. Have to run them to the jbbfe pins 1(high) and 2(low) on the blue connector for PT can H/L. Once I did this was able to redo coding and no more 2FA4 error. Guess MSD81 needs CAS on the network to not get this error.
I also updated this KD CAN cable's atmel firmware. I'm not sure if this helped, but flashing in WinFKP took longer this time in comfort mode. Redid coding once again and surprise, still no 2FA4 error. The firmware probably didn't help with this but nice to have.
Now what about mileage in the donor DME? how do we check the stored mileage? Once I change the ISN with FC200, mileage goes to 0 in the UIF. I don't think FC200 zero's out mileage but maybe it did? IS there a job intool32 that can show stored mileage?
As long as stored mileage is lower than CAS it will update to the higher mileage once driven?
