    Jul 2012
    Slovakia
    Default MB w211 edc16cp31 exhaust back pressure sensor disable
    Can someone doit
    its w211 3.0 crdi 2008 year
    edc16cp31
    Dpf and egr already made, but car does not go when sensor discconnected. When connected there is problem with turbo shaking at 2200-2600rpm
    erasing dtc p0472 is not enough
    stanislav georgiev's Avatar
    Oct 2014
    България
    Test it, it should be OK.
  3. The Following User Says Thank You to stanislav georgiev For This Useful Post:
    pcbox (16th November, 2022)
    Jul 2012
    Slovakia
    Quote Originally Posted by stanislav georgiev View Post
    Car not start with your file. I now had to use bdm to retrieve bring it back to live.
    Jul 2020
    do you want to delete the back pressure or the pressure difference sensor ?
    Jul 2020
    Car needs the back pressure to work , just change the sensor , you can't delete it .
    Oct 2014
    България
    The car won't start because your tool has made a new checksum adjustment.
