Results 1 to 15 of 19
    Nov 2022
    Germany
    Default P0610 Need ECU data repair
    Hello guys. I need a help with my wife Mazda 3 (Petrol 1.6). After a year of time, i decided to repair speedometer.
    I read the data from ECU and dash. And i didn't know what was wrong, someone can help me to look this data and maybe fix this ?
    fuzz1's Avatar
    Jul 2019
    please describe what problems you facing with your speedometer
    Year of car
    Photos of the speedometer
    Nov 2022
    Germany
    Quote Originally Posted by fuzz1 View Post
    Year of car
    The car year is 2004. Speedometer doesn't not count kilometers and only show speed 0 km/h
    rafal's Avatar
    UK - PL
    here fixed dump....................
  5. The Following User Says Thank You to rafal For This Useful Post:
    MartinSUK (19th November, 2022)
    Nov 2022
    Germany
    Quote Originally Posted by rafal View Post
    I write this file to ECU, unfortunately problem is still 😔
    rafal's Avatar
    UK - PL
    Quote Originally Posted by MartinSUK View Post
    I write this file to ECU, unfortunately problem is still 
    make diagnostic and post dtc.............
    was before p0610 ?
    i fixed dump and now is correct
    fuzz1's Avatar
    Jul 2019
    Any fault codes?
    Any signs of corrosion on either the ECU or the speedometer?
    rafal's Avatar
    UK - PL
    Or read again eeprom and compare. Maybe you wrote your Ori file.
  10. #9
    Nov 2022
    Germany
    I compare this file and two symbol is diffrent B7 to BB and B5 to B9
    Only fault is P0610 and no corossion on ECU
  11. #10
    Nov 2022
    Germany
    When i write second time ECU and put it on car a new error popped up it's p0602 (Faul programming) in this time on HEX code car nothing changed.
    Engine not starting.
  12. #11
    ricked's Avatar
    Apr 2016
    Europe
    try this file
  13. The Following User Says Thank You to ricked For This Useful Post:
    MartinSUK (20th November, 2022)
  14. #12
    gwiazdamb's Avatar
    Aug 2022
    PL EU
    This is an old solution and it works, if not, check 005B FB=FF program a new 93c56 memory
    PLEASE PRESS THE " THANKS " BUTTON
  15. The Following 2 Users Say Thank You to gwiazdamb For This Useful Post:
    MartinSUK (20th November, 2022), rafal (20th November, 2022)
  16. #13
    Nov 2022
    Germany
    Quote Originally Posted by ricked View Post
    try this file
    What is the password?
  17. #14
    ricked's Avatar
    Apr 2016
    Europe
    Quote Originally Posted by gwiazdamb View Post
    correct...
  18. #15
    ricked's Avatar
    Apr 2016
    Europe
    dont be lazy and pm me, i have not time to pm every one.....
  19. The Following User Says Thank You to ricked For This Useful Post:
    rafal (22nd November, 2022)
