    br556hre's Avatar
    Exclamation EDC16C34 - cruise control HELP (PSA 1.6HDI 80kW)
    Anyone able to fix cruise control to work under 40 km/h?
    Currently you cannot start cruise control if vehicle speed is not 40km/h or greater. I tried all I know with 9HZ damoses - but no luck.
    Read is from 9HY engine without DPF from factory and there is no DAMOS for it as far as I know.
    File is almost original - just MAP sensor upgraded and glow plugs monitoring disabled.
    Please help!
    Here is ktag read:
    Jun 2013
    EU
    Try 0x1C91F0 16 bit HiLo 0.01 factor and 0x1C9210 16bit also same factor
    Good luck
    br556hre's Avatar
    I have also thought this two locations are CrCCD_vSetSpdMin_C and CrCtl_vAlwMin_C but.. changing this two values does not make any difference what so ever.
    Any other help is appreciated!
    Jun 2013
    EU
    CrCtl_rVnDvtShutOff_C
    br556hre's Avatar
    Thanks Morgano for helping out at damos closest to my file default value of CrCtl_rVnDvtShutOff_C is 02100 16bit HiLo, I have increased it up to 32767 to give more space to speed (v/n) deviation - no change what so ever - CC does not turn on if not above 40 km/h.
    Another interesting thing.. setting value just before it (CrCtl_rVnDvtAbs_C)to 00900 16bit HiLo allowed me to have cruise active also in 1st, 2nd and 3rd gear instead of 4th and 5th gear only, but still only above 40km/h.
    I'm starting to think BSI have something to do with this, but I have no proof of this..
    Any other ideas or suggestions how to make it work from 20km/h?
    br556hre's Avatar
