Results 1 to 14 of 14
    May 2020
    Default VW EDC17CP14 r/w via OBD with KESS V2 (clone)
    Hi guys, i need your help
    I want to remove ecology from my private scirocco, and I'm just learning the basics of chiptuning
    I made a backup and read the flash (looks like it's not full) in boot mode using kess V2 (clone)
    Is there any method to upload the converted flash via OBD using kess (clone) or the only option is to buy ktag and unlock Tprot via bdm?
    Jan 2021
    Germany
    Unfortunately your sw begins with 17503 and you have to patch it with K-Tag.
    Another solution is flashing pre-dieselgate sw without Tprot via ODIS
    May 2020
    Quote Originally Posted by werner1337 View Post
    Ok, I have VAS and I can downgrade the firmware using ODIS, but then I will lose the current map prepared on the dyno by the tuner?
    gwiazdamb's Avatar
    Aug 2022
    PL EU
    This is how you will lose the map from your tuner
    PLEASE PRESS THE " THANKS " BUTTON
  5. The Following User Says Thank You to gwiazdamb For This Useful Post:
    martinorlando (30th November, 2022)
    Aug 2015
    just write back file using kess BOOT mode same as you read it, it is not full file since you read it with kess but boot mode with kess+tricore adapter works very well
    you are bypassing tprot of course on boot mode, don't be afraid because it is not full file, it is the way KESS + tricore module works on boot, it is confusing for a lot of people especially beginners. Just write file same as you read it (don't write backup, write maps only) ,no need to buy ktag
  7. The Following User Says Thank You to dtip For This Useful Post:
    marss (15th December, 2022)
  8. #6
    May 2020
    it seems to me that this process will not work in the case of my ECU, it is probably too young , sw 6656 is currently loaded
    Quote Originally Posted by dtip View Post
    you are bypassing tprot of course on boot mode, don't be afraid because it is not full file, it is the way KESS + tricore module works on boot, it is confusing for a lot of people especially beginners. Just write file same as you read it (don't write backup, write maps only) , no need to buy ktag
    I know I can upload the map back via boot mode, but I want to be able to upload maps for tests via OBD without opening the ecu every time. The car is used daily.
  9. #7
    Jun 2013
    EU
    Quote Originally Posted by marss View Post
    Use virtual read then
  10. #8
    May 2020
    Quote Originally Posted by morgano View Post
    I only have KESS V2 5.017 (clone), so vr is rather unavailable for me. Unless there is an option to upload the necessary file to the KESS database?
  11. #9
    Jun 2013
    EU
    Here it is VR for your ecu.
    You need use protocol 501 to write it OBD.
    Make any mod you want over this file and flash the moded file OBD using the mentioned protocol, it should work. In the event your ecu brick you can recover it with the backup you made in bootmode before.
    regards,
    Here immo data should you really face a disaster while playing and really kill ecu.
    VIN: WVW***********978
    CS: 3E19D06E7C3300
    MAC: 0AE6A27A
    PIN: 33681
    You can always clone it in another good ecu
  12. The Following 2 Users Say Thank You to morgano For This Useful Post:
    marss (2nd December, 2022), tunepwn (3rd April, 2024)
  13. #10
    Jun 2022
    Switzerland
    GET THE KTAG AND REMOVE TPROT UPLOAD FILE VIA BOOT AND THAN YOU CAN USE OBD READ WRITE
  14. #11
    May 2020
    After removing the DPF via DaVinci, do I have to recalculate the checksum before uploading the maps in the boot mode option?
    Does kess calculate the checksum itself also in boot mode?
  15. #12
    Luigi84's Avatar
    Dec 2022
    Italy
    Kess calculates the checksum, but da vinci clone makes a disaster with the dpf ..
  16. #13
    qni666's Avatar
    Mar 2019
    Bulgaria
    i not reccomend use davinci in edc17 manual solution or swiftec
    WANT PASSWORD ? PRESS THANKS AND ADD REPUTATION AFTER THAT CAN ASK ME PASS PM
  17. #14
    May 2020
    Quote Originally Posted by Luigi84 View Post
    Quote Originally Posted by qni666 View Post
    yes, I guess DaVinci is not good for EDC17 and that's why I'm looking for some solution and I wrote a message to you Luigi84, because it's too high level for me .
    But Swiftec did exactly what DaVinci did ...
