Results 1 to 10 of 10
    Jun 2009
    Default FIAT 500 1.4 T-JET 0261S15048 10SW004733 ori file needed
    I need FLEX reding or similar 2048kb file.
    Abarth 595 1.4 Turbo 180HP
    Manual Gearbox
    MY 2017
    ME17.3.0
    HW: 0261S15048
    SW: 10SW004733
    Full Flash
    Sep 2012
    Here you go.
    Give Thanks and Rep.
  3. The Following User Says Thank You to pericadex For This Useful Post:
    BIOS (1st December, 2022)
    Jun 2009
    I need full flash 2048kb.
    Your file is partial reading 1.536kb.
    Do you have full flash reading?
    Max001's Avatar
    Sep 2018
    Italy
    File Service Dpf Egr AdBlue Dtc Tva Swirl Kat Off and more
  6. The Following User Says Thank You to Max001 For This Useful Post:
    BIOS (2nd December, 2022)
    Jun 2009
    Quote Originally Posted by Max001 View Post
    File is 1.5Mb ,not a full flash.
    Do You have full flash reading,2048Kb ?
  8. #6
    Max001's Avatar
    Sep 2018
    Italy
    you can write this file if you have original kess.
    I don't have 2mb files
  9. #7
    Jun 2009
    No problem to write it.But, I need full flash.
  10. #8
    carmageddon's Avatar
    Italy
    me17.3.0 have 1,5 mb and is full...which tool need 2 mb? maybe obd write? because boot R/W is 1,5 mb...if need 2 mb for obd write is only because the tool made VR with this size...not because 2 mb is full!
  11. #9
    Jun 2009
    Flex , bench reading.2Mb.
  12. #10
    Italy
    ok....but is personalization for flex R-W....mms add the portion that does not exsist on boot reading...the size for this cpu is 1.5 mb, not 2mb...next time be more precise with data info when search original file, is fundamental
  13. The Following User Says Thank You to carmageddon For This Useful Post:
