Results 1 to 11 of 11
    dd1's Avatar
    Aug 2014
    Default BMW 3 E92 DME SWAP error
    Hello everyone, i have swapped a DME on this 2013 bmw 328 N55 with the same part number. i have cloned it but i have this error 375C " DME protection against tampering. program or data manipulation detected" can someone help me to fix this issue? i have not started the car yet, since the DME is located under the intake. thank you in advance
    Feb 2021
    Do DME-CAS adjustment. Did you clone it properly?
    dd1's Avatar
    Aug 2014
    Quote Originally Posted by TheNine90 View Post
    thank you, my main issue is how to get the error taken care off, the rest should ok, i know the car will start but it will have an error. to start this car, i have to finish up my work, which means the intake manifold has to be installed. i really do not want to do the job twice. i want to make sure everything is ready then i will finish it up. i have used the ktag, the clone tool.
    Feb 2021
    Try flashing it. If it doesnt work then the clone was not done properly
    Apr 2016
    you need stop doing bmw cars as everytime you post in forum for the help time to rethink your work.
    rules !!!
    dd1's Avatar
    Aug 2014
    You mean reprogram using ISTA?
    Feb 2021
    Winkfp or istap
  8. The Following User Says Thank You to TheNine90 For This Useful Post:
    dd1 (8th December, 2022)
    dd1's Avatar
    Aug 2014
    Winkfp or istap
    it wont be the MOTOR HOURS correct?
  10. #9
    Feb 2021
    Flashing wont reset working hours
  11. #10
    Mar 2017
    Egypt
    I don't work on E series, but if you fully clone it, no need to flash.
    DME protection occures due to incorrect coding ex. power class which needs working hours reset.
    Some DMEs has FSC installed, you have to check them.
    I know as well some E series US DMEs needs extra working on ECU board, you have to fully check what i told you.
    Good luck.
  12. The Following User Says Thank You to mwahab For This Useful Post:
    dd1 (12th December, 2022)
  13. #11
    dd1's Avatar
    Aug 2014
    Quote Originally Posted by mwahab View Post
    Good luck.
    thank you, the working hours, is it possible via obd2 or has to be bench only?
