Hello Everyone,
I have a problem with Audi A6 C7 2.0 TDI CNHA 2014.
Information popped up that in 1000 km I will not start the car (that's true - it won't start, just read the errors to add 50 km range).
I read the error codes and got:
28653 - Reductant System Performance Bank 1
P204F 00 [039] - Malfunction
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Error status: 00000001
Error priority: 2
Error rate: 1
Mileage: 261,712 km
I have never been any similar error like e.g. Nox sensor error. Only this P204F.
Clean error codes doesn't reset the counter on dashboard.
I have done:
- checked reductant injector, quantity test - I got 25ml. Long term adaptation is 1.00.
- checked pump pressure - it's correct (around 5000hPa)
- cleaned the urea tank, filled the tank new adblue and reset level many times by VCDS
- SCR reset by VCDS
- cleaned the injector in ultrasonic cleaner
- cleaned Nox sensor by special cleaning agent for EGR and exhaust systems
- updated the software version in ECU - from 8244 to 8284
- performed test procedures. (Driving 60-90km/h with a constant load for over a kilometer, driving at 100km/h in 3rd, 4th gear for over a kilometer, etc.)
- reductant test by VCDS (where we have to hold the brake and accelerator pedal until the procedure is completed - always end succesfully, but sometimes it takes a second, sometimes more than 6 minutes)
DPF and SCR systems work while driving.
I found that urea quality sensor shows 0.0%. I've read on other forums that users also have 0.0%, but they don't have any error.
I attach below ZIP file with logs.
Maybe someone had similar problem and help me.
Thank you in advance.
