Results 1 to 5 of 5
    Apr 2021
    İZMİR TURKEY
    Default BMW F30 N20B20A Need wiring diagram..
    I need wiring diagram for BMW F30. Thanks for support.
    Feb 2021
    What specifically do you need? Wiring for ECU?
    Jan 2023
    https://ia801005.us.archive.org/11/i...0%20Engine.pdf
    Quote Originally Posted by furkanhfu View Post
    Dec 2013
    If you need specific wiring send a VIN number.
    May 2024
    Quote Originally Posted by xsashox View Post
    Hello, I would actually like to take that offer. I have a BMW 2012 F30 320i that won't start. When I try to turn the ignition on the dashboard briefly lights up but goes dead right after. I suspect a short or bad ground in the engine wiring harness. After trying to move and unplug some cables, I found out that by unplugging a 3 white wire plug the dashboard suddenly lights up and stays on but the car won't start. If I plug it back in, same thing happens, if I turn the ignition on it lights up very briefly and goes dead again. So anyway, big headache, but with the wiring diagram I should be able to find the issue more precisely, I think that part of the harness is called the transmission module. I sent you the VIN in private, I would greatly appreciate if you could provide me the wiring diagram. Thanks in advance!
