Page 83 of 854 FirstFirst ... 3373787980818283848586878893133183583 ... LastLast
Results 1,231 to 1,245 of 12803
  1. #1231
    angelx431's Avatar
    Sep 2010
    BG Sofia Madrid
    Quote Originally Posted by botioni2002 View Post
    iS THER A WORKING 912 DUMP?
    Free no.....
  2. #1232
    Jan 2011
    Quote Originally Posted by angelx431 View Post
    Free no.....
    How much does it cost and where can I buy this dump?
  3. #1233
    Quote Originally Posted by bibkare View Post
    try it with and without crack, it should be OK either way
    Ok, I'll keep that in mind.
  4. #1234
    Oct 2008
    On Earth
    Quote Originally Posted by amstel7 View Post
    You can find 908 dumps for free in this forum, don't waist your money for 912
    If you haven't anything to do with your money please you can make a donation to DK and become a Forum Supporter.
    Good luck
  5. #1235
    Tereksaz's Avatar
    Nov 2010
    Dark side of the Moon
    not free.
    only for exchange
  6. #1236
    brasil
    Default He/she doubts cable VCDS812
    Hello my cable apare?e USB\VID_0403&PID_FA20\RT000001 the one what would this last one be I number RT\000001?
    Pedro
  7. #1237
    Junior Member max4ever's Avatar
    Romania
    @ Tereksaz
    not free.
    only for exchange
    Instead of what?
  8. #1238
    Newbie s3mick's Avatar
    wakefield uk
    Hi all. i followed the tutorial to reflash my cable to 805 but no luck, i may not have removed all the vagcom software so i will try again, in the tutorial it says to copy the vcds_805_soft\hosts to the windows directory to remove the blacklisted serial but i cannot find the file, if anyone could help. Thanks
  9. #1239
    Romania
    my computer\c:\windows\system32\drivers\etc\
  10. #1240
    wakefield uk
    Hi dariusddj, thanks for the quick reply, i must be stupid? do i have to copy vcds_805_soft\hosts to the c:\windows\system32\drivers\etc\ and if so where is vcds_805_soft\hosts. thanks
  11. #1241
    Default Can't see the forest through the trees
    Have spent many hours studying this and believe have gathered everything needed to "fix" this 912 clone, and also maybe program other EEPROMs, like for airbag resets.What I don't have is the understanding of the basics of flashing the chips, even after reading these threads and tutorials. Not sure how to actually begin, how to connect to the FTDI, whether to flash the ATMEGA on the board or off, and if the programmers and adapters I've collected are of any use. Reading that some if not all of these procedures can be done without special equipment. Have wanted to get involved, and learn how it all fits together, and what works and what doesn't.. Trouble is don't have time to experiment, would rather pay someone to fix this clone, or help with what is probably common sense for you guys, or just bite the bullet and buy an original Ross-Tech.
    I don't see a lot of VWs, but still want to have the best coverage I can afford for all makes. The VAG-COM would be a good "scanner" to add to the collection: Genisys, MT2500, AutoEnginuity, CarDaq+, HIM, assorted ELM and generic interfaces. (Big thanks to DK members for HDS and Techstream among other valuable resources)
    So anyone , preferably in US who can help me directly by phone or send VAG-COM to you for modding. I will make it worth your time..If it helps others, also will gladly share what I've learned here, and have experienced over the last 30 or so years.. Please reply or PM me ....Thanks to all
  12. #1242
    Reading through again, and tutorials. I should spend a few hours to try. It's already broke, so it couldn't hurt too much. Still not sure of the GAL16V8, not mentioned in 805 tutorial, but is in Final Solution (Thanks AMINEBOT) Will play with it this weekend..Thanks again
  13. #1243
    Oct 2008
    On Earth
    Quote Originally Posted by s3mick View Post
    Creat a hosts file in the c:\windows\system32\drivers\etc\ with this line:
    127.0.0.1 update.ross-tech.com
    Good luck
  14. #1244
    Romania
    unpack the rar file and copy to c:\windows\system32\drivers\etc\
  15. #1245
    Romania
    Quote Originally Posted by kevinb2u View Post
    this is all you need
  16. The Following User Says Thank You to dariusddj For This Useful Post:
    zemaitis (25th February, 2018)
