Page 16 of 854 FirstFirst ... 611121314151617181920212666116516 ... LastLast
Results 226 to 240 of 12803
  1. #226
    i used the tutorial. direct connection to atmega using ponyprog and flashed 1.83. i then used arash 908 using ponyprog.
    i then used mprog to write 232r EPT which i used before to fix my broken cable.
    only thing i haven't done is remove components and linked 3 wires (atmega, FT and GAL).
    i used the cable once but now it don't seem to connect any more.
    should i try again but remove the components and wire up?
  2. #227
    DK Veteran bibkare's Avatar
    B & H
    Quote Originally Posted by tazman13 View Post
    I suppose that you have interface with ft232 inside, just do exactly like in this solution http://www.digital-kaos.co.uk/forums...hip-ft232r.rar
    @nemesiz12 You should do this on win xp (it's safer)
    Sometimes when you connect interface , windows ask for drivers and you can not install your interface with any drivers , in this case do the following steps:
    - Go to "Device manager".
    - Search for your device (with yellow icon).
    - Go to "Property" of device.
    - You will see the "VID" (Vendor ID) and "PID" (Product ID)
    write these numbers and use XOOM's udfixer (big respect to Xoom) to create new drivers, now you can install your interface, it will say something different than usb serial device but it doesn't matter after installation of drivers run mprog and erase ftdi eeprom choose new vcds eeprom and program it, i have to go now Hoffenheim leads 2-0 it's 3-0 now
  3. The Following 7 Users Say Thank You to bibkare For This Useful Post:
    ecufix (14th March, 2021), frogear (28th January, 2018), girolamodisidisi (5th October, 2019), mallll (1st September, 2021), mobilni (12th December, 2020), Vrin (14th August, 2019), zZarZiLLoSs (25th May, 2020)
  4. #228
    Quote Originally Posted by bibkare View Post
    can i continue without programing the GAL as i have no solution?
  5. #229
    Oct 2010
    i downlaod the eprom from here VCDS 10.6.0 work witch chinese clone
    have to flash the rft232rl with mprog or ftprog or it is equal?
  6. #230
    B & H
    Quote Originally Posted by Nemesiz12 View Post
    Mate you don't read just few post above i told you that
    look here http://www.digital-kaos.co.uk/forums...tml#post827461
  7. #231
    Oct 2010
    Moin
    so in post 235 you say i should use mprog in post 230 i should
    use ftprog -> therefore i ask again!
    even i tried to install the driver but when i generate the driver and install it, the Windows device manager occurred a Message
    as VID an PID I shown in the proberties the device -> details->Hardware ID-> USB\VID_0403&PID_6001&REV_0600
    as VID i use 0403 and PID 0600
    the programm create the driver but when i want to install it
    a driver for the device was found but a error occurred during the installation
    UDFfixer by bloom
    The system could not find the stated file.
    What i make wrong?
    Thanks for your help
  8. #232
    xoom's Avatar
    Ylakiai
    VID_0403&PID_6001
    and you saying that you enter PID 0600
    thats why you getting error. and for your vid/pid no need different drivers.. use drivers from ftdichip.com
    FT_Prog is newer version then MProg3.5
    You are not concentrated what you are doing..
    "UDFfixer by bloom" even this prove that
    so take care what you are doing and follow instructions exactly bibkare explained
  9. #233
    Oct 2010
    im trying to find vag-com 311 softwere, where can i find it
  10. #234
    xoom's Avatar
    Ylakiai
    Quote Originally Posted by robert cummings View Post
    Now is replaced with VCDS-Lite
  11. #235
    Hi, i am looking for v908 ENG installer (chinese cable).. I lost my installation disc. Pls could someone upload one or point me the direction for one.
  12. #236
    Quote Originally Posted by kingsh View Post
    look here 100 loader and 150 loader
    http://www.sinoytool.com/info/Downloads/
  13. #237
    Oct 2010
    Quote Originally Posted by xoom View Post
    VID_0403&PID_6001
    after flash the rft232rl windows show in the device manager as a P with exclamation point the PID are changed to 4204.
    How I know i correct flash the cable?
    in ft prog i choose -> scan and parse->File-> open Template
    than i choose VCDS 908 FT232RL.xml
    than -> Device-> program
    I wait and in the left corner above the Window a Message with complete occurred.
    Is this correct or the cable damaged?
    in the attachment is a picture.
    What a bith :-)
  14. #238
    well i have flashed 1.83 again along with arash 908 eeprom. removed the stc etc and added 3 wires and still my cable don't see my car.
    i cannot do the GAL as i don't have programmer.
    i have tried 100 loader and 908mod and still don't work.
    what could be wrong?
    i think cable is dead now.....
  15. #239
    xoom's Avatar
    Ylakiai
    @Nemesiz12
    this is not correct.. try after you change vid/pid for drivers then you should install your cable wit these drivers .. then you fire up your ftprog or mprog and delete whole eeprom.. then replug it.. and then you can apply you ross-tech file
    @tazman13
    if it was with ft232rl you have to reprogram GAL..
  16. #240
    Oct 2010
    @Nemesiz12
    @tazman13
    That is what i try to do!!
    In the Mornig i
    take the UDfixer but a error during the installation occurred than i have found the Option let Windows search a driver over the Internet. I do it Windows7 found a driver and install it USB to serial driver.
    Than i Have take the tool ftprog and flash the eeprom with
    VCDS 908 FT232RL.xml <- from arash
    After flash the PID was changed from 6001 to 4204
    ->see attachment.
    and now
    when i try to use the UDFixer, it generate a driver with
    the VID and new PID but when i want to install it
    a error occurred -> see attachment.
    than i have Windows let search a driver over the internet
    but now no driver found.
    What i make wrong ????
    Thank you for your Help
    I precive you make flashing oftener.
