Page 308 of 854 FirstFirst ... 208258298303304305306307308309310311312313318358408808 ... LastLast
Results 4,606 to 4,620 of 12803
  1. #4606
    @gvafious: Yes, is very easy to rewrote. Only must read on this thread.
  2. #4607
    Sep 2016
    can you tell something about my problem?
  3. #4608
    keyzex's Avatar
    Jan 2012
    Sweden
    MProg 3.5 - EEPROM Programming Utility
    http://www.ftdichip.com/Support/Utilities.htm
  4. #4609
    Sep 2016
    Quote Originally Posted by keyzex View Post
    a little more info about how to use/do it? thanks!
  5. #4610
    Sep 2016
    Quote Originally Posted by mccloud90 View Post
    i flashed VCDSFT232BL.ept with MProg and now my cable is broken Please HELP I need my cable working again
  6. #4611
    Feb 2013
    What ept have you used? From were? And why?
    When you start doing something, be sure you know enough to finish it.
    If you have problem with your cable: first you find dumps for atmega and a programmer, than you write ftdi with mProg and go further to atmega using a hardware usb programmer for atmel; offcourse you need a power source 12v cc and a computer. And most important read this huge thread to find answers or take a shortcut and use "search".
    Have fun!
  7. #4612
    Sep 2016
    Quote Originally Posted by alexm1 View Post
    Have fun!
    VAG-COM MULTI STUFF\1.VCDS COLLECTION\12.12.0 for BM-BL-RL ... this is a set of files i found on the internet, in some forum.
    I tried to update because it was for the same ftdi, i was hoping that in some way my fields will be able to show the whole info for me. Tell me what programmer i should buy to do it. i have got TL866CS Programmer should this be ok if i unsolder and solder the atmega? i have plcc44 socket for the programmer? or i need to do it with AVR Programmer?
  8. #4613
    Feb 2013
    No need to desolder atmega, use AVR prog. it is safer and faster; and AVR prog. it is cheap to buy.
    And when are ready to reflash use entire set of files : ept flash eeprom .
    Avr prog needs a software - use Xtreme Burner.
    You should know that long coding does not work with 12 12 0 , you need to use 11.11.5 for coding with same dump.
  9. #4614
    Sep 2016
    ok one last question. Can i reflash atmega with ktag? it use the same cable? i can buy avr programmer but i will have to wait. I have ktag in my hands? can i use it to flash eeprom like on the ECU?
    and can i flash newer version of the vcds on this cable? for example 14 or newer? i need to find dumps for it. So flash ftdi(.ept with Mprog), next atmega with flash and eeprom (via external programmer) ? Thanks! Do you have some working for sure dump files( i mean when there is a group for "Fuel Temperature" to write it full, not only Temperature"? Thanks!
  10. #4615
    Apr 2016
    hi Guys,
    such a huge thread - i cant read every page...
    i have a VAG912 cable, on win 7 it worked well. but now on win10 it won?t.
    the software: vag 908 and vag912 beta dont start on win 10. what can i do? is it possible to update my old cable to use newer vag com software?
    USB view shows me this
    Device Descriptor:
    bcdUSB: 0x0200
    bDeviceClass: 0x00
    bDeviceSubClass: 0x00
    bDeviceProtocol: 0x00
    bMaxPacketSize0: 0x08 (8)
    idVendor: 0x0409 (NEC)
    idProduct: 0x0058
    bcdDevice: 0x0600
    iManufacturer: 0x01
    iProduct: 0x02
    iSerialNumber: 0x03
    bNumConfigurations: 0x01
    ConnectionStatus: DeviceConnected
    Current Config Value: 0x01
    Device Bus Speed: Full
    Device Address: 0x08
    Open Pipes: 2
    Endpoint Descriptor:
    bEndpointAddress: 0x81
    Transfer Type: Bulk
    wMaxPacketSize: 0x0040 (64)
    bInterval: 0x00
    bEndpointAddress: 0x02
    Transfer Type: Bulk
    bInterval: 0x00
  11. #4616
    First:
    idProduct: 0x0058
    Are you sure?
    Please, VID_ and PID_...
    VCDS have 0403/FA24 or 0403/FA24.
    Second:
    In W8+ must disable digital driver signature verify
    http://www.howtogeek.com/167723/how-...igned-drivers/
    Third:
    Is verry possible VAG 912 is deprecated. SO..maybe will need to upgrade the cable to..15.7.3..16.8.3...
    If find eeprom for free, will be free. If not.....that is!
  12. #4617
    Jul 2014
    I get news from fly , fvdi 2 can do audi a6,a7,a8 and vw touareg generation 5 all key lost by OBD , key maker is ok too , who know ?
  13. #4618
    electronistul21's Avatar
    Nov 2011
    galati,romania
    yes,can.but in this thread talk about Vag-com
    Carprog 8.21,xprog 5.55,galletto v54,kess and ktag rework
  14. #4619
    Jan 2017
    Hello.
    Here are flash dumps for latest VAG-COM original + flash dump of China clone FW 1.96 with protection chip. All firmwares are disassembled. It's quite easy to decrypt HCC196.bin (old 512 byte bootlader) from install directory. I'm working on other tools such as FLASH and EEPROM dumper via USB, so it can be read even with fuse bits set.
    BTW according to FW source code - fuse bits are not read by firmware itself, so it doesn't care if the fuse bits are set or not.
    HCC196.bin is for old HW type (0x44) with PORTA.2 and PORTA.3 connected to GAL
    HP196.bin is for new HW type (0x46) - not decryptable yet (no public). May be this type is used in China clone. CN Clone dump is not the same as HCC196.bin.
    As I know - protection chip doesn't protect ATMega (according to schematic I don't know how it can protect it) but is used as a "key" for cracked VCDS distributed with VAG-COM. It communicates with VCDS loader through RTS/CTS pins of FTDI. If VCDS loader finds the protection chip, it then unlocks communication with ATMega, creates d1-d3 files and starts VCDS.
  15. The Following 6 Users Say Thank You to engycz For This Useful Post:
    cosmin12345 (17th April, 2017), Gyula84 (23rd October, 2018), MOTORSPORT PROG (7th April, 2019), radioman (22nd February, 2019), seal777 (22nd March, 2021), sep382 (18th January, 2022)
  16. #4620
    Jan 2017
    Default Simply procedure flash dead Cable + SW
    Quote Originally Posted by engycz View Post
    Hello.
    Here are flash dumps for latest VAG-COM original + flash dump of China clone FW 1.96 with protection chip. All firmwares are disassembled. It's quite easy to decrypt HCC196.bin (old 256 byte bootlader) from install directory. I'm working on other tools such as FLASH and EEPROM dumper via USB, so it can be read even with fuse bits set.
    Hello it is simple procedure Flash Atmel via USB and need VCDS loader. Thank you
