Page 354 of 854 FirstFirst ... 254304344349350351352353354355356357358359364404454 ... LastLast
Results 5,296 to 5,310 of 12803
  1. #5296
    Oct 2014
    Netherlands
    Go a couple of pages back, there is a posting where 3 links are posted about V2 loader. Atleast 2 links are valid.
    In the archive you can find latest firmware/eeprom files for the 2 supported hardware types.
    You can check which hardware type you have using one of the tools in the archive, or post some pictures of your cable here (or compare it with posted pics).
    Rgs H2Deetoo
  2. #5297
    Mar 2017
    This is my cable vag 912 i check all the pages and i found a lot of way to update but i dont understand which is better and faster for my case can you help me?
  3. #5298
    Oct 2014
    Netherlands
    Run HWtype tool and check which version you have. Remove STC chip before programming, no need to put it back.
    Use some AVR programmer like USBASP to flash your avr (solder wires to it)
  4. #5299
    Jul 2016
    Vilnius
    Why everyone is upgrading to the latest version?? Does it work properly for you? Valid adaptation channels, long codings, etc?
    * MK100
  5. #5300
    Oct 2014
    Netherlands
    To be honest I haven't fully tested my upgraded cable yet, I only did a quick test to see if the cable was working again.
    How can the problems you describe come from either the fw upgrade or the loader?
    And what version of fw or loader or vcds is working for you then?
  6. #5301
    Oct 2014
    Netherlands
    I just did a test with cluster on table and indeed when selecting adaptation channel staging i see a mileage value. This is with VCDS 17.8
    But version 17.1.0 seems to work fine though.
  7. #5302
    Oct 2014
    Do these files work on a genuine RT cable?
    I have a couple RT cables that were accidentally plugged into a laptop that had 17.1 clone software on it and online, now the cables will not work, must have blacklisted the serial numbers.
    I have talked to RT and they advised to send them back for repair @ near the price of a new cable. I have been searching and reading a lot of these posts but seems it is mostly talking about
    clones and making them work with the loader file.
    Is there any way to restore the RT cable?
  8. #5303
    Oct 2014
    Netherlands
    I don't know your exact problem because you didn't specify, but try to use VCDS 17.0 together with Kolimer's V2 loader (this will patch VCDS and disable some checks).
    Perhaps this is enough to make use of your cable again.
    If the AVR firmware or eeprom in the cable is really damaged then indeed you must fix this.
    I guess you can use the files from Kolimer's package, because they are real dumps afaik.
    (Please correct me if I'm stating something wrong ...)
  9. #5304
    Nov 2017
    this is my working 1.84FW 10.6.4 cable. I want to flash firmware to use newer VCDS.
    HWtype tools says "no response", is it because the cable is not connected to the car?
    Do I need USBASP or can I flash this one just connected via USB?
    Thanks in advance.
  10. #5305
    Jan 2017
    Connect to USB 12v, and open VAGCOM_EEWrite as Admin.
    I think that will help you.
    Please let me know if it works.
  11. #5306
    Nov 2017
    Hi, thanks for your reply.
    But USB on the computer is only powered with 5V. You mean external 12V to the OBD connector (GND pin 5 and 12V pin 16?)?
    Is it important which driver version is installed?
    Thanks!
  12. #5307
    Oct 2014
    Netherlands
    Yes, put 12v to the OBD connecter (or plug in car).
    Not so important which FTDI driver is installed.
    If you don't get a response, then start try your 10.6.4 software, and do the TEST.
    Once your
    10.6.4 software reports something about your cable, close it, and start again the EEWrite tool.
    (this worked for my with my 15.7.0 clone, it needs to unlock communications with the ATMega it seems.)
  13. #5308
    Nov 2017
    Default YES
    Quote Originally Posted by ironderek View Post
    Does Chinese clones 908/912 works with 64bit OS? I found some drivers on the net but during instalation I've getting message that drivers are old, and need to be update. Do you have working drivers for 64bit OS?
    Cheers.
    THERE IS MANY CLONES THAT WORK WITH THIS ON 64 I AM USING WIN7 64 AND 3 DIFFERENT ONES the programs were altered by fantomel and his collection of software is spread across net ,google fantomel's vag collection and there will be all u need .
  14. #5309
    Oct 2014
    Netherlands
    I've read and experienced with different cables already that they don't reply, unless you first start the software with came with it to unlock at the ATMega.
    Can anybody explain what exactly is done to achieve this?
    Is there some special command sent? Or some specific pattern on some output pin?
    Regards,
    H2Deetoo
  15. #5310
    Jan 2017
    Hey,
    I downloaded version 17.10.0 EN and it does not work for me with Loader_v2. There is no communication with CAN vehicles. License is active but not connected to vehicles. Polish version 17.8.0 does not have encoding descriptions. Do you have any idea how to fix this or what is wrong? With version 17.8.0 EN all works well. My interface looks like this:
