Page 439 of 854 FirstFirst ... 339389429434435436437438439440441442443444449489539 ... LastLast
Results 6,571 to 6,585 of 12803
  1. #6571
    May 2018
    Quote Originally Posted by kaalis View Post
    First test your cable with A4 B5. And it don't use CAN for diagnostics. Only K1 and K2.
    What engine you have in that B4? Let's hope it's not a 2.3 10v or 2.0 16v trash.
    ok, will try that
    1.9 TDI 1Z
    Edit: Cable works fine on Audi A4 B5, but it wont connect to Audi 80 B4. I have read that B4 has a hard time connecting to anything. is there anything i can do to improve that?
  2. #6572
    Dec 2014
    PL
    Phoeny
    That's why I wrote that vcds lite 1.2 is better for older cars. To speed up communication with the Audi B4 you need to change the START BAUD from "0" to 9600. In vcds lite 1.2 you can do it many times. With vcds hex can start baud you can set before the first connection (OPTION) of the cable. You need to install the software again and set the start baud.
    Try.
  3. The Following User Says Thank You to Mario6 For This Useful Post:
    Phoeny (2nd August, 2018)
  4. #6573
    Hello, I bought VCDS 18.2 clone running with 1.12 loader.
    http://oi63.tinypic.com/35mjtqo.jpg
    http://oi63.tinypic.com/30sy80o.jpg
    When I connect it to car, it blinks red and thank lights solid green. After running software and trying test, while connected to car, it says: port ok, interface not found. On the other hand, when connected only to laptop interface is found with status: Not plugged into Car. Anyone has idea how to solve issue?
  5. #6574
    EU
    Seller ignores you?
  6. #6575
    Europe
    Kolimer's loader 6.3 its working well
  7. #6576
    EU
    Quote Originally Posted by Mario6 View Post
    It's the same as simply editing vcds.cfg?
  8. #6577
    Dec 2014
    PL
    kaalis
    This changes the data transfer speed from 0 to 9600 (eg Opel 10400). Nothing more. Helps in connection with older Audi A4 and A6 engines.
  9. #6578
    Apr 2018
    Quote Originally Posted by ericas View Post
    Hello guys. I have flashed about 10 VCDS (15.7 RED PCB, 12.12 GREEN and 17.0, 17.8) with kolimers v4 and v5 loader, everything was fine. But now i am stuck. I don't know why but last 3 VCDS clone 17.8.1 i cant reflash with USBasp - when i first time conected i can read chip, i add PROJECT from v5 and PRESS AUTO. Atmega starting programming but after about 10 s i geting error (somthing about can't verify flash or...), and i am try second time with project from v4 - this same problem. After 3-4 times programming i getting another ERROR - CANT ENABLE CHIP. And no more cant read ATMEGA. I have 3 same interfaces now with same problem.
    Attachment 544378Attachment 544377
    Please share a real photo from your own PCB, otherwise we cannot help as proper as we would like
    Because I made these pics from my cable about 4 months ago. If you check the AT162, you will see a written 182 sign on the top. This interface came like a 18.2 cable and it's type is HW44 and running proper with Kolimer's v6.3
  10. #6579
    EU
    But don't need to reinstall vcds to change this value. If it really helps or not.
    It's read by vcds once program starts. Need to restart vcds so it would read edited config again.
    Never used it really in A4 B5, A6 C4 and A6 C6. All connections were succesfull using default 0.
    Does it make initial connection with these 20 year old cars faster? Sorry, haven't tested it.
  11. The Following User Says Thank You to kaalis For This Useful Post:
    Mario6 (4th August, 2018)
  12. #6580
    Dec 2014
    PL
    I changed Start Baud to 9600 when I could not connect to the engine at all. In the Audi a4 1.8T and 1.9 Tdi, 2.5 Tdi has helped. I did not have to do it in all old cars.
  13. #6581
    Feb 2018
    Belarus. Brest
    Default VCDS 18.2.1 RUS
    Д
    Good afternoon, tell me with what loader VCDS 18.2.1 RUS will work (Russian)?Good afternoon, tell me with what loader VCDS 18.2.1 will work (it's Russian)?
  14. #6582
    Dec 2014
    PL
    Aleks1975S
    Use Kolimers loader v 6.3. I used and 18.2.1 PL works.
    http://ru.ross-tech.com/?page_id=431&lang=ru
  15. #6583
    Mar 2018
    Hello!
    44HW can you upload the 46 firmware? If I tell what's happening?
    thx
  16. #6584
    Feb 2018
    Belarus. Brest
    [QUOTE = Mario6; 3341341] Aleks1975S
    Использовать погрузчик Kolimers v 6.3. Я использовал и 18.2.1 PL работает.
    http://ru.ross-tech.com/?page_id=431&lang=ru [/ QUOTE]
    Кolimers v 6.3, VCDS 18.2.1 RUS no works
  17. #6585
    May 2016
    Kaunas
    Quote Originally Posted by Aleks1975S View Post
    Did you write the RUS EEPROM?
