I programmed Atmega, than start 18.2. All went ok till i insteled 18.9. Now i have in test (not connected to the car). I`d reflash again and installed 18.2, but the same problem. What can i do with that?.
Also VAGCOM_HWType shows no response.
Forgot connecting to 12v?
One stupid question: maybe I'm from another planet, but I'm using v.18.9 with the loader v.7.0 and have not any ideas, what does "AKP" mean. WTF is the AKP? ))) Don't kick me, guys...
vcds translated in polish language: (vcds.pl)
Hi ElRomano.
I like your post. Greetings from Poland
Guys, in order to flash VCDS eeprom, may I connect 12V probe of a power supply (output: 12V 15A) to obd2 PIN 16 and (GND) probe to PIN 5 instead of connecting the cable to the car?
Should I care of the current (ampers) power supply gives at output? Thanks
Connect the vcds via obd on the car and flash ;-)
Using loader 7.1 with latest drv without flashing interface.
miouser (26th November, 2018)
Please, need some help
I have VCDS Atmega162 from china - Well after a take a picture i see it actualy is atmel
https://imgur.com/5udY3GK
https://imgur.com/Kk4yEUX
I Flashed with VAGCOM_EEWriteLang chossing Portuguese - PTT, but when start VCDS 18.9 PTT it is shows unlicensed and unregistered.
Any way to fix it ?
EDIT: I think it works with Loader v7.1. I will test soon. message "unlincensed" is gone
using the loader?
kaalis (17th November, 2018)
LC DON'T work well on 18.9.0 last version 18 oct signed (aka v3). Tested on both hw type.
