Page 49 of 854 FirstFirst ... 3944454647484950515253545999149549 ... LastLast
Results 721 to 735 of 12803
  1. #721
    Dec 2010
    Czech Republic
    Quote Originally Posted by KenshinPT View Post
    I remember that I read in the erased VCDS thread that the new VCDS 10.6.x as new security.
    If you test a device with a black listed serial your doomed. VCDS 10.6.x will something bad to your computer that you'll never be able to use your clone VCDS again unless you format your PC or if you find what VCDS did to your computer...
    ...Maybe an entry in the register?!
    Anyone here can confirm this story?
    my computer is still alive and working but anyway some cleanup should be help, because now I haven't idea which driver is really in the system (during the test 3-4 versions of VCDS..)..
    anyway, from 10.6.3 was everytime corrupted small eeprom for FTDI on my clone .. that what I saw yet..
  2. #722
    DK Veteran KenshinPT's Avatar
    PT
    Quote Originally Posted by tr3ce13 View Post
    Nothing in register, reprogram atmega, reinstall drivers (908 have older drivers)... try a virtual machine before format.
    When I said format, it was just a way to say =)
    The virtual machine was/is my only option.
    How do you know that there is nothing related to that supposed protection from VCDS in the register?!
    I found lots of entrys in the register pointed to "c:\rosstech\vcds" even when I erased everything.
    I found other entries in the desktop, but that's just were I store the installers and what so ever...
    Did it help? Push Thanks below
  3. #723
    PT
    Quote Originally Posted by tomasfilip View Post
    You can remove the drivers in the Add/Remove programs in the Control Panel.
    The entry is something like: "Windows Driver Package - Ross Tech"
  4. #724
    Dec 2010
    Czech Republic
    good to know, I want to use also program from FTDI, is called FTClean they will delete all drivers regarding VID/PID
  5. #725
    PT
    Are you talking about that 8 pin SOIC 93C56 eeprom?
    Do you have the original dumps for that eeprom?
    I never understood what was the point of that eeprom. Is it related to FTDI?
  6. #726
    angelx431's Avatar
    Sep 2010
    BG Sofia Madrid
    Your Uninstaller!
  7. #727
    Dec 2010
    Czech Republic
    yes, in the cable are two eeprom. One is related to the FTDI (hold configuration of USB) and second is in Atmel (hold serial key)
    What Rosstech do, is scrap sometimes this FTDI-EEPROM (If identify clone is connected), so cable next time isn't recognize as "Ross-tech HEX USB" cable but as Serial USB Converter (in better case) or worst case you need special VID/PID driver to install driver for this 'device' and than you can fix with sometool from the internet (or my tool from package)
    so this eeprom hold VID/PID, some serial number (isn't same [probably] as in inside of Atmel-EEPROM, settings for USB, Identification text and others stuff..
    My Idea, what I want to try soon is assembled here 93LC76 or 93LC86 and try it, because this eeprom has PE (program enable) pin.. So Rosstech doesn't kill my device again..
    On this position is allowed 93LC46/93LC56..etc.. Datasheet doesn't talking about 93LC76/93LC86.. but should be works (probably datasheet from FTDI is old)
    The tool for FTDI eeprom access is called MProg, now is newest version but MProg is still accessible from webpage..
    About contains, I have contains different then RT0001, but is from clone.
    When you look on my package some thread ago, there is package 7MB, inside is program "Eeprom programmer_RTQX65IX.exe"
    for run needs also library FTD2XX_NET, try run.. you will see what happend.. It Is working like MPROG, but is simplest..
  8. #728
    Nov 2010
  9. #729
    PT
    After removing everything related to VCDS from my computer, including drivers and removing all VCDS entries from the register I started all over again with FLASH1.81 and EEPROM908.0.
    Everything is ok now!!!!
    But now I wanna test with FLASH1.83 and EEPROM908.0 to see what happens!
    Maybe this issue was due to the instalation of VCDS10.6.3 and after a register delete the problem was solved... maybe?!?! or maybe not... Let's see.
  10. #730
    Dec 2010
    Czech Republic
    I just order from Farnell 93LC86 eeprom
    part number: 1196821, MICROCHIP|93LC86-I/SN|EEPROM SERIAL 16K, 93LC86, SOIC8 | Farnell United Kingdom
    , we will see soon ..
  11. #731
    Nov 2010
  12. #732
    Dec 2010
    Maybe the stupid question ....but how to remove all VCDS entries from the register....
    I have "Ross tech USB driver package 6020" but cannot remove it by add/remove programs because i get "error"(attached file)...so how to remove that easily
  13. #733
    Nov 2010
  14. #734
    Dec 2010
    In windows 7 / vista
    Start, run, devmgmt.msc
    In usb devices rigth button, uninstall and mark remove software.
    or use FTClean
    FTclean did his job-thanks...but under device manager cannot find that drivers for uninstallation-stil have "Ross tech USB driver package 6020" and the same problem...tried to use common uninstallers (revo uninstaller) but no help...i have installed obviously that drivers and somehow removed the software but the drivers stayed....but if ft clean cleaned everything i can start form the beginning..am i right?
  15. #735
    Nov 2010
