Page 543 of 854 FirstFirst ... 43443493533538539540541542543544545546547548553593643 ... LastLast
Results 8,131 to 8,145 of 12803
  1. #8131
    Mar 2018
    Quote Originally Posted by da78n View Post
    So you suggest to completely remove the IC8 (STC), to unsolder him from the board ?
    The interface is working without the STC or i have to solder him again after writing the firmware?
    What is that STC doing ?
    Delete it and throw it far away, it restores eeprom Atmega162 and does not allow to work firmware
    liviudiaconuwrote to you to remove them, and do not forget to remove the diode D7
  2. The Following User Says Thank You to Roma77 For This Useful Post:
    da78n (18th April, 2019)
  3. #8132
    IF (REMEMBER only IF) Avr write CORECTLY AVR ATMRGA162 then you will obtain in HWType 46 and ROSS TECH 46
    IF (REMEMBER only IF) this happend and IF CDDAFF(or CDDAF9CC) then USB Writer must write correctly by USB k0l1 flash and eeprom.
    IF NOT..something is wrong. OR..IF after exclude STC (IC8 ) and D9 the same ..probably FT232R is damaged.
    As i see you do something wrong or STC is damaged or put short-circuit on FT. If i have that cable in my hands will be more easy. "At the distance" is dificult to repair...
    And YES, i suggest TO ALL exclude STC and D9. Not always that not let communicate FT232-16V8-Atmel...but time to time..is happend,,randomly. "Howgh!!!" - as Winnetou said
  4. The Following User Says Thank You to liviudiaconu For This Useful Post:
  5. #8133
    Apr 2019
    Europe
    Post
    I removed IC8 and D7.
    Flashed the interface with AVRdude.
    Everithing looks ok
    Tried VAGCOM_EEWriteLang.exe and it's working.
    After USB update with VAGCOM_EEWriteLang.exe VCDS also requested and did firmware update.
    I will test it tomorrow on the car since now is too late but it looks good.
    Thank you all for the support.
    PS: will it work with VCDS-Release-18.9.1 or must use only VCDS-Release-18.9.0 ?
  6. The Following User Says Thank You to da78n For This Useful Post:
    traxpalicaru (15th May, 2019)
  7. #8134
    Feb 2013
    Will work only with 18.9.0. Maybe in the near future this "problem" will be solved by Kolimer .
  8. #8135
    Oct 2018
    Quote Originally Posted by tino3 View Post
    Here is the link for downloading the VCDS 18.9.0 installation in Czech.
    https://uloz.to/!Uspjvr6r07zo/vcds-18-9-0-cz-zip
    Link doesn`t work any more.
    Can somebody upload it once more?
  9. #8136
    uk
    Hi thanks for the 2 option link my last one was a ebay vcds 12.12 still working ,but would like to get a another one .Whats the difference between the 2 options and which one is better many thanks !!
  10. #8137
    uk
    Quote Originally Posted by Roma77 View Post
    I have very good news friends, the obd2cartool store and special thanks to Julie (great2obd) efforts, for all users of our forum there is a special link to 2 products with a big discount and free shipping DIY VAG / VAG V2 Choose option one or option two.
    And now think for yourself what to buy: a quality product for a good price with a guarantee and technical support or shit with Ali.
    Option 1:
    Classic DIY ATMEGA162 + FT232RL + L9637D + 16V8B cable with Bootloader - 19.12 Euro
    Option 2:
    HEX-V2 DIY ATMEGA162 + FT232RQ + 9241 + 16V8B +ATA6561 cable with Bootloader - 26.97 Evro
    https://www.obd2cartool.com/vip-cust...gh1jgm4016dpr2Euro
  11. #8138
    Mar 2018
    Quote Originally Posted by zakdk View Post
    if you are not hampered by the budget, then I advise option 2, but the first one also works fine.
    Only consider that both options are calculated on the fact that you will use the Kolimer package for firmware.
    you can see the difference between them by clicking on the link option 1 option 2 click here
    There is also another news friends, I read on the forums that the diagnostics of cars of new 2017-2019, if the scanner does not see all the blocks, you need to open the hood.
    Request to forum users to check who has the opportunity and unsubscribe here.
  12. #8139
    May 2011
    hi, i want to ask did you test yours 18.2.1/18.9 vcds with CAN car?
    I bought cable from this guy: https://www.aliexpress.com/store/pro...28c64e18ReHu8B
    cable came with vcds 18.2.1polish/18.9ENG and with vcds_loader ver7 and of course vcds 18.2.1 AKP polish or 18.9 english could be registered (OPTIONS->TEST->SAVE k1=ok k2=ok CAN=Ok) but it works only with car equipped in KKL line but any car which has got CAN can't be connected without error communication info.
    I'm getting communication errors windows each time i want to scan/autoscan or direct access any car's component,
    i have got older version 17.1.3polish/17.8ENG from same guy and this version with different older loader works OK
    please answer:
    1.did you test your 18.2.1 polish / 18.9 ENG with any CAN/UDS car ?
    2. can i check using some tools which versions of "firmware" has got my cable ?
  13. #8140
    Mar 2018
    Quote Originally Posted by psgpol View Post
    please answer:
    Well, here's another shit with Ali)), you can find and download everything you need for this scanner to work on this forum, everything works fine, read carefully the info file in the archive.
    https://www.digital-kaos.co.uk/forum...=1#post3444869
    if you have a multimeter stop the resistance at 6 and 14 pin OBD should be 120om
    If this does not help, try to remove, replace the diode that I noted in the photo.
    https://prnt.sc/ne3rqa
  14. #8141
    Mar 2019
    What I have found is this, but I did not test it yet:
    "Hey Guys,i found out that MQB Cars are still codeable and readable with a HEX CAN Cable.
    There is just a verification on the new VCDS Software.
    To readout newer MQB Modell cars you need to:
    1. Turn on ignition
    2. Do autoscan on the car
    3. Turn off the ignition
    4. Select the desired Module
    5. Turn on the ignition
    With this you bypass VCDS to readout the Cars modellyear and
    all information will be still displayed.
    I think they just put this to sell new HEX V2 Cables"
  15. #8142
    Mar 2018
    Quote Originally Posted by bg17aw View Post
    1. Turn on ignition
    I know about this thanks, but at this moment we are talking about raising the hood for diagnosis (Toureg, Q7 and so on 2017-19 )
  16. #8143
    Oct 2018
    hi, i want to ask did you test yours 18.2.1/18.9 vcds with CAN car?.....
    You should use with 18.9 vcds loader v.7.2
  17. #8144
    Jan 2016
    From VCDS Germany distributor...
    Important NOTE:
    Due to a bug in the current VCDS 18.9 resetting the service interval in the control unit 17 is not possible. In this case, we recommend you to downgrade to the VCDS 17.8 until the bug in the next VCDS version has been corrected.
  18. #8145
    Member Jerak's Avatar
    Jan 2011
    Canada
    I know about this thanks, but at this moment we are talking about raising the hood for diagnosis (Toureg, Q7 and so on)
    Quote Originally Posted by jakuza View Post
    Important NOTE:
    I just reset the Service Reminder and Distance and Time based Service reminders with 17-Adaptation 10 on a 2014 Touareg with VCDS 18.2 and the classic cable.
    I don't know about the newer model Touareg though.
