Page 562 of 854 FirstFirst ... 62462512552557558559560561562563564565566567572612662 ... LastLast
Results 8,416 to 8,430 of 12803
  1. #8416
    Jul 2017
    Quote Originally Posted by lemta View Post
    I'm not sure if I am understanding this correctly. Are you saying this version works on people that have ARM or NEC chip instead of the Atmel162 chip?
    So I have a Hex V2 with ARM chip that came with 17.1.3 software (without loader). Will this version work without flash programming?
    Once this v19.6.0c is installed is it possible to revert back to old software if needed? Many thanks for the answers.
    That's right. The easiest way to take and check. You do not risk anything.
  2. The Following User Says Thank You to BASi77 For This Useful Post:
    lemta (12th June, 2019)
  3. #8417
    Member lemta's Avatar
    Jun 2012
    Quote Originally Posted by BASi77 View Post
    Will the cable not get killed if the serial is blacklisted in the software? There is no known way to flash it to work again if that is the case.
    What I also don't understand is how it is so easy to just install the software on the ARM cable whereas everyone else with ATmega162 chip needs Kolimer's modified loader in order to bypass security. How can it be that easy?!!
  4. #8418
    Jul 2017
    NEC and ARM devices are not killed.
    The device will work. Of course, provided that this device works with version 17.1.3.
  5. The Following User Says Thank You to BASi77 For This Useful Post:
  6. #8419
    Nov 2015
    home
    Big Thanks kolimer
  7. #8420
    Jul 2017
    Will the cable not get killed if the serial is blacklisted in the software? ...
    If you look at the pictures from the post #8420. You will see that the serial number in the device is one and in the license it is different.
  8. #8421
    EU
    Do not require flashing. As a bonus CAN commands sniffer.
    Thanks, interesting. Got it working on cable that was "made" for 17.8.0 version. Did connect engine ecu through CAN but K lines in cable were already fried before.
    One observation. RT-usb.dll is missing in C-Tools directory for C-test.exe to run properly.
    This version is using 32bit vcds.exe from original 19.6.0 released May 31th.
    Just a guess: modified RT-usb.dll and custom RT-logs.dll?
  9. #8422
    Jul 2017
    Well, something must be different from the original.
    And what about CAN commands sniffer. C-Sniffer.log can be useful when simulating blocks when debugging. When deciding the issue with MY 2019+.
  10. #8423
    Jun 2012
    So I installed v19.6.0c onto my cable shipped with v17.1.3 ARM chip. It activated ok but when doing auto-scan from modules 44 onwards IIRC it errors cannot access the modules. When it gets to the end the application closes itself down.
    EDIT: Also there is no way to cleanly uninstall software. I am running 64bit Windows 10 - could the 32bit v19.6.0 be the problem? EDIT2: Actually I'm not even sure the v19.6.0c is 32bit version, just thought I read something that it said it was.
  11. #8424
    Mar 2018
    Here is a link to the installation file 19.6.0 for NEC, ARM and all the others with FW-1.96 only.
    new :
    http://ge.tt/9R9AXZw2
    http://www.mediafire.com/file/q1qqel....6.0c.zip/file
    Your programs work on Atmega 162 I use firmware 0x46 for atmega 162 from the loader 7.2 package and the scanner works with both Russian 18.9.0 and your 19.6.0.For can sniffer thanks, very useful program.
  12. The Following 2 Users Say Thank You to Roma77 For This Useful Post:
    Col19 (25th June, 2019), seal777 (22nd August, 2019)
  13. #8425
    Sep 2016
    I checked the VCDS-HC-19.6.0 c version by connecting on the table to 2 units
    1- the 2010 dashboard
    2 - the 2006 getway using the ATmega cable and noticed a few features
    1) When you first connect the cable sees the installation sheet but after a short time it ceases to see it
    The first connection
    after a short time
    To make everything work you need to close and reopen VCDS
    2) Connecting to the dashboard writes "Unsupported Vehicle" although it is 2010 release
    3) If immediately after you run VCDS to connect to supported units that it will work, but if you hold the connection he always will write "Unsupported Vehicle"
    Immediately after the launch of VCDS
    After a short time after starting the VCDS
  14. The Following 2 Users Say Thank You to elpaso544 For This Useful Post:
    Col19 (25th June, 2019), RiHard (13th June, 2019)
  15. #8426
    Sep 2016
    C-Sniffer Work better)
  16. The Following User Says Thank You to elpaso544 For This Useful Post:
  17. #8427
    Jul 2016
    Vilnius
    Funny enough that both, "Unsupported vehicle" and "Function not supported by GW" are Dicatator's issues...
    * MK100
  18. #8428
    Sep 2016
    Quote Originally Posted by hid3 View Post
    Wait for the loader 8.1
  19. #8429
    Jun 2012
    Quote Originally Posted by Roma77 View Post
    How did you get 18.9.0 working with BASi77's program? What did you keep of the v19. 6.0c?
  20. #8430
    Mar 2018
    I do not quite understand what you want to know.
    I have a program 18.9.0 Russian with a loader 7.2, I installed another program from BASI77 19.6.0 and both of them work, I did not save anything anywhere.
