Page 626 of 854 FirstFirst ... 126526576616621622623624625626627628629630631636676726 ... LastLast
Results 9,376 to 9,390 of 12803
  1. #9376
    Mar 2017
    If it's updated by programmer you don't have to activate first.
  2. #9377
    Mar 2017
    Quote Originally Posted by heshamzn View Post
    R u Aware of what happens there ?? r u gonna take the cable with damn virus
    you can't take the "damn virus" through package.
  3. #9378
    Newbie Andeboy's Avatar
    Feb 2020
    Magyarország
    Cable old shopping once. Onto 1 notebook registered. I wanted to run it on more machines .the kilomer turned out with a packet to be valid and like this on more notebooks can be used. excuse me my English knowledge
  4. #9379
    Top Poster nicolas2015's Avatar
    Feb 2015
    somewhere in cornwall
    Hello again, a quick update, i ordered this cable- https://www.obd2cartool.com/vip-link...kt5hmlc2js9tu3. Ordered on the 16.2.2020 and arrived on the 24.2.2020. With the colleague- liviudiaconu and with another colleague/s patience-jan4, much appreciated to both of you for all the help and support, i managed to install the VCDS to current version-19.6.2, tested and working .When i done the first test is saying Can - not ready. After i saved this, i/ve done a scan on the car Audi a4 B6, 2003, checked all the errors, erased a couple of them , and after that i tried to connect to parking aid module 76, to adjust buzzer volume, but surprise- no response from controller. I/ve used kolimer loader , and followed all the instructions , eewrite, hw test, etc. But no joy to read the damn parking aid module. Any ideas?
    Vag-com, Op-com, Focom, Autocom,Multidiag, Forscan, Lexia....
  5. #9380
    i had the same problem sometimes, and i did the test 2 times, and 2nd time Can Ready OK then saved. You should try several times, it should work...
    Sent from my SM-G970F using Tapatalk
  6. The Following User Says Thank You to mrben For This Useful Post:
    nicolas2015 (25th February, 2020)
  7. #9381
    EU
    CAN no ready for a A4 B6. That's as it should be.
    Not connecting to parkings.
    - module itself is bad (as last choice; didn't read it's detecting objects behind bumper)
    - CAN wires to instrument cluster are broken
    - K wire is not connected from module to car itself.
    Should be quite easy fix if you are able to use multimeter.
  8. The Following 2 Users Say Thank You to kaalis For This Useful Post:
    liviudiaconu (26th February, 2020), nicolas2015 (26th February, 2020)
  9. #9382
    His car is 2003. Real CAN was implemented after 2005?-2006?
    Can Gateway can be present (19) but not diagnosed on CAN. No LC..
    But your ideas are very good. A multimetter is mandatory.
  10. The Following User Says Thank You to liviudiaconu For This Useful Post:
  11. #9383
    May 2019
    Hi guys . I have a mid 2016 , golf 7 1.6tdi engine code cxxb and i bought a cheap clone version with vcds 19.6.1 , i wasnt able to enter the engine code module neither adjust or long coding anything inside the module ....anyone knows a good working version to buy compatible with all modules in this car ? The error i get is "service not supported in active session"
  12. #9384
    Feb 2015
    Just order the one in the link that i posted. Arrived in 8 days, you need to install a few things, it’s working perfectly!
  13. #9385
    Feb 2015
    The story: the buzzer is working , highest volume setting probably, sensors are working, all the intensity, basically the vcds is not connecting to the module, to adjust the volume/ to do adaptation. I will try your suggestions and reply. Many thanks.
  14. #9386
    EU
    Passat B6. Yes, diagnostics through CAN gateway.
    Audi B6/B7. No, still in K dinosaur era. Instrument cluster #17 has integrated primitive gateway but not accessible through #19.
  15. The Following 3 Users Say Thank You to kaalis For This Useful Post:
    jakuza (4th March, 2020), liviudiaconu (26th February, 2020), nicolas2015 (26th February, 2020)
  16. #9387
    Feb 2020
    I have a chinese version of cable ( 12.12 ) .
    Can u help me with a loader or something to relicense/update the cable?
    Thank you!
  17. #9388
    Jul 2016
    Vilnius
    Yet one more.
    Unfortunately, this cable is useless - it doesn't have GAL logic chip, so in fact it's neither 0x44 nor 0x46.
    It's good as a donor for spare parts though - you can donate it to me, some members have already done that and cables have been successfully parted out to resurrect 'normal' ones
    * MK100
  18. #9389
    EU
    Quote Originally Posted by nicolas2015 View Post
    It's weird because the tool is connecting to other modules that need 2nd k wire, but not to 76- parking aid. Just to mention rear parking sensors are working perfectly, i just need to adjust the volume as it's too loud. Pictures attached, also any ideas of upgrading this tool ? It's 11.11.3, i had it since 2013 and it's working Okay, i've been doing adaptations, coding, code reading and errasing fault codes. many thanks. Or any idea where to buy a good reliable newer version?
    Interesting that this cable doesn't have voltage regulator but similar cable two posts before mine does have it.
    Already wrote about parkings. BTW, are you able to connect to other devices on K2? Radio, Aux heat, headligt range?
  19. #9390
    Feb 2015
    The problem is not from the VCDS( 11.11.3- or 19.6.2), the module is aftermarket, i found when i remove bits in the trunk. Both interfaces are connecting to radio( on K2) but it seems that this time i used wrong approach, many thanks for all the help and patience, i will try and find original PDC module, sensors, cable, etc...
  20. The Following 2 Users Say Thank You to nicolas2015 For This Useful Post:
    kaalis (28th February, 2020), liviudiaconu (29th February, 2020)
