VCDS Hex-V2 with main chip STM32F405VGT6
VCDS hex-v2 is also available in the following languages:
Chinese, Croatian, Czech, Danish, English, French, German, Hungarian, Italian, Polish, Portuguese, Romanian, Russian, Spanish, Swedish
VCDS Hex-V2 with main chip STM32F405VGT6 is the best ross-tech vcds hex-v2 clone.
Col19 (25th December, 2020), olivier8877 (30th December, 2020)
Hi, i have a VAG106 clone cable which was working well until last month, but i lost the Disc and format my laptop.
I tried to instal VCDS 10.6.0 and its drivers but when i connect the cable and TEST in VCDS, i obtain "NOT PLUGGED INTO CAR"
Cable connect only to OBD, led green
Cable connect OBD and USB, led red
I think the problem is a not correct drivers or software, someone have the correct one?
Thanks!
Hi I’m getting ROD: ERROR ..... and also “upgrade to a current Ross-tech interface” please help.
I got my interface hex v2. 100% working. Simple and quick instalation. VIIPlusLoader is multilanguage? only need to add icon of version vcds.
I got my interfa
Hello, I have a clone cable
VCDS software version: 15.7 Firmware version: 1.94
Original full chip edition: ATMEGA162 + 16V8B + FT232RL
Could i update to v20.12 and how?
@bombardino
try and report.
@Gracek
manages to enter the control units bb, bc?
in the gatway list are the control units d6 and d7 present? (only if you have led matrix headlights)
Could you elaborate about that a bit?
If I could guess (I did some work on this back in the days) the they are still using RSA for public key encryption and these cloners have dumped the original VCDS cable and extracted the private/public key?
Anyway.
I have three of these clone cables atm. One is using the STM32F405 protected using RDP leved 2 and the other two is using the STM32F415 and is protected using RDP level 1.
I have successfully dumped RDP level 2 protected chips by double glitching but its far more easy to glitch the system bootloader when the chip is set to RDP level 1
All these three cables are using the same serial number (displayed in the VCDS sw) and is locked to support VCDS 20.4.1 only. That is the unmodified/uncracked version of VCDS 20.4.1
I also ordered a VCDS that should support upgrades but I canceled the order once I was informed that it would require a loader for the upgrade.
However I got a copy of the update software and a video on how to do the upgrade and it looks like this upgrader is made by the cloner.
The software itself is protected using vmprotect but I have some experience reversing this protector so will try to extract the VCDS firmware from it when I get the time. (I believe it is embedded in the exe file and not downloaded on the fly)
Oh! Please let me know if such a dump already exists so I don't waste my time inventing the wheel all over again
regards
VCDS Hex-V2 with main chip STM32F405VGT6 uses VIIPlusLoader to open ross-tech v2 software and update it
Has anyone tested if Hex V1 is capable od winding in rear callipers on newer VAG cars like VW Golf mk7, Passat b8 etc. Till Around 2017/18. Will it work?
Can someone tell me if the cable on the right support updates?
It uses the 405 chip but I bought it as a 20.4.1 only before these upgradable cables was on sale.
Cable on the left is the 415 and if I understand this correctly this does not support updates? Or at least not using the VIILoader?
This is the chip I will try to dump and see whats on it.
Col19 (29th December, 2020)
hallo badrax, please, can you write the link where to buy that one on the right. Thank you
