Does it work with golf 7? / Hex v2 arm
Did anyone test kolimer with golf 7?
Hello Badrax, thank's for your very good job and respect.
I am waiting for my new cable like this PCB: Attachment 779876
Question: if I copy its firmware with the STLINK like this:
Can i extract the .bin of my cable easy with a ST STLINK (whith correct pinnouts on the STM32F405VGT6) .
and flash it with this if a upgrade fail?
Attachment 779865
I am interesed by the .bin file of the entire memory of the STM32
Regards.
PS: I am french and my English is no good...
Look in your Startup, maybe will see a command like "vcds.exe update" or something else.
Delete-it.
Or, Options-> "User interface...." tab, choose "Do not check for updates" insted "Release only", save..close VCDS and look in startup. Teoreticaly the command "vcds.exe update" must disapear.
If not, delete-it.
bg17aw (10th February, 2021)
The STM chip on these cables are most likely read protected so you cant just read out the content with a ST-Link debugger.
You could be lucky and hope they forgot to set the RDP level and if so you can read out the whole chip.
If RDP is set then the only way I know of to dump the content is using fault injection like voltage glitching.
If RDP2 is used then you will have to double glitch. First glitch from RDP2 -> RDP1 and then glitch the system bootloader when reading.
Check out wallet.fail and or chip.fail. They use voltage glitching to go from RDP2 to RDP1 for so to dump the RAM content.
It will require some more effort to dump the flash.
But. You could be lucky and get a cable set to RDP0
regards
yes, this vcds hex-v2 work with golf 7
bg17aw
in the registry windows 7 it is here
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Shared Tools\MSConfig\startupfolder\C:^Users^PCname^AppDa ta^Roaming^Microsoft^Windows^Start Menu^Programs^Startup^RT-Updater.lnk
K2 connection fixed. Waiting for official to release it public.
Hey everyone,
anyone knows the PIN assignment of the 7 pin header? USB cable ground is placed on the most right pin (7).
Want to flash the interface USBASP soon - shouldn't make problems or?
Thanks!
this is what you are searching for ;
simply use a mm to follow the connector to the pins of the atmega162
donbrisko (27th January, 2021)
Hello badrax,
ST-Link can disable RDP1 but delete memory..., and i think's that it can't for RDP2.
It's very difficult to disable RDP1 without deleting the memory.
I have looked at Wallet.fail and Chip.fail but it's very complicated for my level.
when my cable arrive, i look if it is set to RDP0 but isn't Christmas...
Regards.
VCDS 20.12.0 HGJ (20210129 DS322.1) released
SHA1: aa29301574b5b21f27e7c73ae9ea8940604a8c5f
VIIPlusLoader-08.021.03-EN-Installer.rar mega.nz download link:
https://mega.nz/file/Ak0FCAAZ#uOq-2e...fOFuIhRDS5wY78
Changelog: modify k2 bugs.
Achtuhr (31st January, 2021), AYD (31st January, 2021), Col19 (6th February, 2021), digiservice (31st January, 2021), DYXiCZ (6th February, 2021), jan4 (31st January, 2021), JTengyel (31st January, 2021), kaalis (31st January, 2021), liviudiaconu (31st January, 2021), miouser (31st January, 2021), mrle9 (31st January, 2021), seal777 (4th February, 2021), Tib82 (31st January, 2021), tobyb (31st January, 2021)
