Download and instal VCD$ Lite 1.2 Full.
Post #11
https://www.digital-kaos.co.uk/forum...light=vag+vcds
Post #11
Yes thank you I downloaded that, it only give me option comport 1/2/3/4 to choose from but my cable appears as a usb, I dont know how to change it in device manager to a comport, any ideas pretty sure i need the VAG KKL drivers, but which ones ?
rosstech is the blue cable,
https://imgur.com/a/Ks0Od6c
Thera are usually two options for the blue cable - ftdi chip or ch340 - open it and check whats inside and then try to install drivers , normally the cable should show up as com
Did you try to use some vag com/vcds older software like 12.12 or lower?
Open the cable and check whats inside
So search for drivers and install shoul show up as comport
Check in device manager what com is set - you can change it to com1 and then try
https://imgur.com/a/bwq91yh
this is what i have now, car not plugged in
This is OK. Cable needs to be powered over OBD port. When you will connect you KKL401, it will find "interface" properly. Only cables with ARM chip can be found without connecting it to the car's OBD.
An idea for my "Autoscan" problem ? I cannot use autoscan with my arm cable. She see not registered. But for modifying it's ok
There is a problem with your software installation..
