Yes, Loader 08.021.04 works well with VCDS 20.21.
If 04 gives problems, try 03.
It does not give License Revoked after use.
Hello everyone!
After doing a doing a 64bit Windows 7 clean installation i can't get the VCDS to work on it. I'm trying to use the 21.3 version with the 9.2 Kolimer loader because i have the Atmega chip HEX V2 clone and it just refuses to run...it shows up for a fraction of a second in the Task Manager and it changes the extension of the original VCDS.exe to VCDS.exeL . I ran out of ideas and i'm open for new suggestions.
Thank you!
Hello
Can you activate the individual TPMS sensor using VCDS on a VW?
VIIPlusLoader 08.021.09 available @ BIGGEST VCDS & VAG-COM COLLECTION EVER!!! UP TO 21.9.0!!! INCL. LOADER - NO PASS!!! .
AYD (7th September, 2021), chora (8th September, 2021), Chrisdiag (12th September, 2021), crouchinggerbil (7th September, 2021), electronistul21 (10th September, 2021), jakuza (22nd September, 2021), liviudiaconu (9th September, 2021), mrle9 (8th September, 2021), seal777 (20th September, 2021)
AYD (7th September, 2021), liviudiaconu (9th September, 2021), Za589 (12th September, 2021)
[QUOTE = Claudiu1992; 4189455]Hello everyone!
Thank you! [/ QUOTE]
have you solve the problem?
I have the same, tryed any OS, win 7, win 10, and it's don't work, after copy the vcdsloader and run, appear the message from kolimer and vcds never run. I'm trying 18.2 version and loader v6.
Someone have any ideas?
Tks in advance.
If it has HL008 chip, then good luck using it as it is.
https://www.digital-kaos.co.uk/forum...=1#post4064543
VIIPlusLoader 08.021.10 available @ BIGGEST VCDS & VAG-COM COLLECTION EVER!!! UP TO 21.9.0!!! INCL. LOADER - NO PASS!!!
It's the BETA version, not Full.
