So you are using a cloned interface and you find it morally acceptable (even though it's obvious that the original developer - Ross-Tech - is affected by this), but then you say that it's not morally right to share that cracked software? This, to me also, sounds like bullshit![]()
Why you even post about a "cracked" software if you don't share it? who do you help with your post if you share only words?
Yeah right, here we share what we have or discovered about the software and cable, everyone else who just post but not share to the community what sustain to have is just bullshit...
Sent from my SM-G970F using Tapatalk
Because he probably is the one who sells that interface and he needs some advertise/publicity for this “perfect VCDS interface”.
He won’t upload nothing if he’s the seller or it has anything to do with that bulgarian seller.
He will post just to tell us how good is that interface and how well the loader works.
Exactly as the chinese seller, and after the people buys it will discover lots of problems and bugs.
I think it is the software from DiagLauter. I can only provide the German 21.3.0 version, I hope it will help. The setup looks original, but it is rebuilt with Indigo Rose Setup Factory 9.5.0.0. During installation, the *.rod files are provided by a self-extracting 7z file. After installation the executing file is vagcom.exe instead of (original) vcds.exe. The vagcom.exe is packed/crypted/obfuscated. My username is the password to unzip, good luck and have fun.
Here are some installers more old that i found on my drive at a quick search, english and german. Install and use the integrated updater if u are in germany or austria and you will get latest version. 50 DOWNLOADS HERE
If you like my post and it helped you please press THANKS.
this looks like same as sklad66 interface maybe this website is just reselling
Col19 (20th November, 2021)
Hello, i buyed a clone cable it has sticker HEX V2 and another sticker B03-V2 21.3 EN. In the small cd is doc file how to install, Installation VCDS 21.3 and Loader (it says v9.1 when start it).
I try to install this setup on notebook with win x86 XP which is running VCDS 12.12 till now....
I start with clean install of this 21.3, i follow the steps where i have to place Loader inside the folder and start it..... On the message when loader starts it says God bless Kolimer v.9.1 and in the left bottom corner it says "Failed 2 x86 v9.1". A window opens with vcds interface then i click Option > Test with the cable in usb. Then message with Yellow mark (like error) apears and says ... Hex + Can USB .....last row say Interface: found ! (or smth like this evereyone know this message).....like cable is not connected.... I tryed on my x64 PC with installing 64 version, on the beginning in launcher it says OK x64 v9.1 instead of "Failed 2", but keep to fail the test in options..... Please help me what i have to do to fix that problem ?
Hi mate first you to see if you have instaled
Microsoft .NET Framework 4.5
https://www.microsoft.com/en-gb/down....aspx?id=30653
Im attaching some pictures to explain
This is 32 bit xp laptopIMG_1883.jpgIMG_1885.jpgIMG_1886.jpgIMG_1887.jpgIMG_1884.jpg
And this is from Win 10 65 bit with installed VCDS 21.3 32bitIMG_1888.jpgIMG_1889.jpg
Creteli im gonna try in a minute but somewhere i read that if Loader Screen shows Failed not OK loader do not work, that scares me more. A friedn of me has 12.12 VCDS with cable, with his version and his cable test goes well without pluged in the care and recieves a longer message with blue circle with !, not yellow like mine
