Page 752 of 854 FirstFirst ... 252652702742747748749750751752753754755756757762802852 ... LastLast
Results 11,266 to 11,280 of 12803
  1. #11266
    Dec 2019
    Romania
    it works perfectly if you start VCDS with loader or direct from the VCDS icon ?
  2. #11267
    Feb 2019
    English without loader.
    Other languages with loader.
  3. #11268
    Dec 2019
    Romania
    I tried 21.9 with loade *.10 Beta and it has a lot of problems.
    I almost cannot do Autoscan, License Revoked, etc.
  4. #11269
    Sep 2012
    Is it possible with some version of VCDS HEX V2 (perhaps older version) to do long coding of unit 46 (comfort) for Audi A4B9 year 2018 ? It look like version 21.9.0. can not do this and all the time come error 31 request out of range. Or it is necessary to use some security access for unit 46 ?
  5. #11270
    Dec 2020
    WhatsApp Image 2021-11-03 at 18.46.21.jpgI have the same car and I have the same problem, I tested the vcds versions from 19.6.2 to 20.12 with chip 405 and VIIloader from version 08.21.01 up to version 08.21.9 and I always have the same problem.
  6. #11271
    Newbie b4b's Avatar
    Aug 2021
    The error has been known for a long time and they have no solution!
  7. #11272
    Dec 2020
    today a friend of mine lent me his cable with 415 chip and without loader with vcds version 20.4.1 the long coding worked quietly, at this point I think it's just a vIIloader problem ..... the cable I have is that of flyobd .....
  8. #11273
    Nov 2021
    Hi! Which auction from aliexpress (or any other place shipping from europe to europe) would you recommend me to buy the vcds cable? I don't have the necessity of updating it in the future as long as it is able to work with seat ibiza 2018. It would be lovely if seat leon 2021 could be also supported, but its not a priority. Thank you in advance for any suggestions.
  9. #11274
    Dec 2020
    Quote Originally Posted by flyfvdi View Post
    Please contact me, our technical support engineers can help u.
    how can i contact you for support?
  10. #11275
    @dgtal81
    if you need support , please contact Tery on skype
  11. #11276
    Nov 2021
    Quote Originally Posted by Creteil View Post
    Just use « VAGCOM_EEWriteLang.exe » program to flash the language corresponding to the VCDS software language you have installed...
    TO DO THAT, THE CABLE MUST BE CONNECTED TO THE CAR WITH CAR CONTACT ON.
    DON'T SWITCH OFF THE CONTACT DURING THE FLASHING PROCESS !!!
    Hello , I tried VCDS 21.9 and loader. The interface works ok and it reads the codes but the long coding doesnt work.
    I flashed the language file to get it to working. Below are screenshots
    HWtype read out
    test v1
    vcds port test
    Issue with long coding/ROD file not found error
    can you please help me how to get the rod file error fixed and long coding helper working?
  12. #11277
    Aug 2018
    France
    @Audi007 :
    your car is A4 B9, correct ? A4 B9 needs HEXV2. Your cāble is hex-can, it’s too old
  13. #11278
    Nov 2021
    My car is 2017 Q7 on MIB platform. The cable i have is Hex-V2 which worked fine on VCDS v18. I also have another cable which is VAG-K + CAN.
    Should i buy another cable with this chipset --> ATMEGA162+16V8+FT232RL
  14. #11279
    EU
    Quote Originally Posted by audi007 View Post
    No, you have hex-can. You may have just a hex-v2 look a like case with non v2 internals.
    Real V2 port test result, about serial is different comparing with your screenshots.
    Sent from my VOG-L29 using Tapatalk
  15. #11280
    XTR's Avatar
    Dec 2020
    Does anyone know when the new VIIPlusLoader 08.021.11 from Fly will be released? Meanwhile, the OEM V2 has received a new firmware.
