Page 832 of 854 FirstFirst ... 332732782822827828829830831832833834835836837842 ... LastLast
Results 12,466 to 12,480 of 12803
  1. #12466
    It's working only with that loader, do not try to updated with viiplusloader at all, your interface will get locked if you update via viiplusloader.
    You must wait for your seller to release a new loader version that works with your interface and send it to you, there's no other way.
    Sent from my SM-A546B using Tapatalk
  2. #12467
    Oct 2023
    Bulgaria
    Okay thanks i try to another windows ( 7 ) without antivirus.
    i have second question
    Can i update software to version 23 with my cable?
    may be i need another flash and loader ?
  3. #12468
    nope, will not work with 23 versions, latest loader for Atmega is Kolimer 9.2 and working only with VCD$ 20.12.0 latest if i remember well
  4. #12469
    May 2018
    Quote Originally Posted by hadrian View Post
    I buyed two vcds-hex-v2 from this seller
    https://vi.aliexpress.com/item/10050...yAdapt=glo2vnm
    These is supposed to be "Free Update Online" but is not. Only the price is for this.
    This guy have updatable and not updatable interface for sale. I payed for updatable.
    Seller sended me download link with Badrax_VIILoader_V9.23.09.001_2303_R1 that work only with vcds 23.3.1.
    If I try to make update to vcds 23.11.0, the loader stop working and message is
    "Please install version BadraxVIILoader_Installer_V9.XX.XX.XXX_2303.exe".
    Exist any solution to make it working or simply I am another sucker who payed to china man ?
    Could you send me this BadraxViiplusloader, please ? i think i can flash my b03 cable and fix it with this firmware.
  5. #12470
    @Fabio89 check your PM
  6. #12471
    Jul 2016
    Vilnius
    Fabio, what will you do after fixing it? Resell the stuff locally?
    * MK100
  7. #12472
    Nov 2023
    Hello. I replaced an ABS pump on my A5 2014. The pump has the same part nr as the old one. However I am struggling with the long coding. Recovering the old coding from the old pump is not an option because the pump is damaged from the crash. Is there an other way to code it besides the regular online code?
  8. #12473
    hadrian's Avatar
    Link for BadraxVIILoader_V9.23.09.001_2303_R1
    https://mega.nz/folder/2YU3wAxZ#THyYgQtNtRWuywp-0A03ZQ
  9. The Following User Says Thank You to hadrian For This Useful Post:
    KoSTeK (30th November, 2023)
  10. #12474
    Nov 2023
    it seems with latest software V23.11.0 , and have SFD function now.
  11. #12475
    Nov 2023
    I get information :
    1.FLY VCDS Hex-V2 SFD function is ok, coming soon.
    2.Added TP16 protocol.
  12. The Following User Says Thank You to SCANNEROBD For This Useful Post:
    seal777 (5th December, 2023)
  13. #12476
    Quote Originally Posted by alwayslearning View Post
    Probably from someone with the same model of your car you can copy the long coding.... or by VIN online from who provide this service
  14. #12477
    Nov 2023
    Hi All, I bought (and successfully used) a VCDS clone cable last year running 22.3 software and using the VCDSLoader to start it. Came to use it again a few days ago and by mistake, still had the WiFi switched on my laptop and now I can't use the software. I've taken my cable apart and it seems to have the ATMEGA162 chip (see attached photos). Is there any way I can re-flash / fix my cable so I can use it again? Many thanks!
  15. #12478
    Nov 2023
    Quote Originally Posted by mrben View Post
    Right then, thank you
  16. #12479
    Top Poster MrDerv's Avatar
    Mar 2023
    UK
    Quote Originally Posted by SCANNEROBD View Post
    SFD is hit or miss, you need to buy a code online to use SFD, and if the code doesn't work, many of these sellers don't offer a refund.
    RossTech are working on enabling this online with VW like OBDeleven does, but its still a little way off yet.
  17. #12480
    Jan 2018
    PL
    Hello
    What interface does this work with?
    Because I have a read device status fail
