Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
  1. #16
    Aug 2015
    GB
    Quote Originally Posted by elektronik325 View Post
    Tre make half protection. 84 or 04. Option two write file immo off, start car and tre make full protection 8c and se if start
    Will try and report...Thx.Br
  2. #17
    Aug 2015
    GB
    With 84 car starts but question is how long?!
  3. #18
    Aug 2015
    GB
    Quote Originally Posted by dedadraz View Post
    No Luck.Car doesnt start anymore!
  4. #19
    May 2016
    BRAIN.EXE
    if you have original eeprom the off it easy but if you forget original dump it need wp 8C and desconected immo
  5. The Following User Says Thank You to tawaf111 For This Useful Post:
    dedadraz (3rd January, 2023)
  6. #20
    al70's Avatar
    Nov 2017
    Éire
    try this with immo box disconnected and use write protection
  7. The Following User Says Thank You to al70 For This Useful Post:
  8. #21
    May 2016
    BRAIN.EXE
    with original dump not need wp 8C but need to desconect immo and plug uce to car .im tested and work unlimited star and full accelerating
  9. #22
    May 2016
    BRAIN.EXE
    IMMO Universal Decoding 3.2 it worked 100/100 IMMO OFF SANGYOUNG
  10. #23
    May 2016
    BRAIN.EXE
    This solution it manuel not need tool tested
    Hi To ALL Brothers For Digita Kaos And Free Solution for Sangyoung with DEPHI eeprom 95160 V1+V2 All ok and car start good without and with WP C8 , And disconnect immo box before connecting the ecu back on the car . not forget to edit your original eeprom not dump from other car to get full accelerating
    V1 95160 LINE HEX 480 TO 499 = 5A5A5A5A5A5A5A5A394800001D4E0000000903300000098404 86 OFF OK
    V2 95160 LINE HEX 4B4 TO 4CD = 5A5A5A5A5A5A5A5A394800001D4E0000000903300000098404 86 OFF OK
    FREE FOR ALL MY BROTHERS AND BIG THANK TO DIGITAL KAOS .
  11. The Following User Says Thank You to tawaf111 For This Useful Post:
    eeprom241 (11th April, 2025)
  12. #24
    May 2016
    BRAIN.EXE
    your dump it V1 edit LINE HEX 480 TO 499 = 5A5A5A5A5A5A5A5A394800001D4E0000000903300000098404 86 OFF OK
  13. #25
    May 2016
    BRAIN.EXE
    Default SANGYOUNG IMO OFF
    This off from you ori dump not forget desconect immo , solution worked Brother but if you lost original dump need to wp 8C
    GOOD LUCK
  14. #26
    May 2016
    BRAIN.EXE
    ALL SANGYOUNG IMMO OFF NEED TO FIND IN HEX LINE WITH A5 A5 A5 A5 A5.... AND EDIT TO 5A5A5A5A5A5A5A5A394800001D4E0000000903300000098404 86 FOR IMMO OFF 100/100
    95160 OR 95320 SAME SOLUTION
  15. #27
    Aug 2015
    GB
    Thx to all i have ori dump...Will try as soon as possible and report.Br
  16. The Following User Says Thank You to dedadraz For This Useful Post:
    tawaf111 (3rd January, 2023)
