hi friends of DK...I need youre help one more time I need the service manual of this equipment..hiab crane 350-5.and if someone have the software to diagnostic and know about how work...thanks
try this link injoy
Unimog Hiab Manuals and Brochures - Hiab 550
thanks...its good....but any service manual now I have some problem with the crane ecm.
Hello can you tell me what problem do you have?
it have remote control? ( scanreco, hetronic, or ???)
yes it has a radio control HIAB by OLDSBERGS and the problem is when I turn on the remote control ...appear the 53 fail code ....inthe service and operator manual reffer to
cause:remote control operating levers are not centered when start up.
remedy: put the remote control levers in neutral position this is ok.
push in the stop button ok
pull out the stop button again. ok
but always appear the same code and crane stop work.
I think I need techial information like how to reset the sistem or how test the levers controls ...resistances and more info.
Try this![]()
thanks but...any technical info?
in the operating manual appear some diagnos software with laptop..I would like to know if that is realy necesary to check the sistem or not.
Hello hercamp
I tried to find that program but i didn't have luck
If you find it pm me
ok...so u have any technical info like the hydraulic sistem or electronic controls???
Try measuring all 6 levers and see if anyone differs from the others.
With Scanreco its easy to remove levers, but the Oldsberg remote isnt built the same way.
If its not to much work, try disconnecting all levers and see if the error dissapears, if so, reconnect them one at a time until the error comes back.
Good luck.
when change the work chanel the crane work normal...I think the problem is the programing configuration or some internal software problems.
someone know where can I buy a remote control ? because have master cyli, level control with different value.....but I vant buy it here hiab local dealer service and parts cant find it ....if you know where or have ever buyed some battery or level...for oldsberg
do someone have operator's manual for any kind of hiab crane?
hello. How to adjust valve hiab 166 in neutral position?
How to make neutral position of levers,?
