Results 1 to 10 of 10
    rtbdiagnostic's Avatar
    May 2015
    My Tool Room
    Default 2016 Chevrolet Cruze B3902-00
    Howzit
    Need some advice have this 2016 Chevrolet Cruze vehicle was jump started incorrectly as a result the engine ECU damaged
    I then cloned data from old to a donor second hand E78 connected it to the vehicle now have the famous B3902-00 dtc cranking but not starting
    Images attached of the old and donor ecu as well as the ori Bcm
    Any advice appreciated
    'If I helped, please click Thanks +Reputation.. !'
    rafal's Avatar
    UK - PL
    open your addys then fix please
    what about sps programming ?
    filutek's Avatar
    Silesia
    Read BCM and ECM, upload here.
    Too low quality photo can't see anything.
    REV# the same?
    IMMODATA ACDelco EXX<=>BCM / BCM MERIVA B REPAIR. ALL CRC-I see it ...
    Jun 2020
    a land unknown
    try 30 minute program to resync
    try to start leave key on 10 minutes until theft light out then turn key off 7 seconds
    repeat 3 times
    works with blade key only
    May 2015
    My Tool Room
    Quote Originally Posted by filutek View Post
    REV# the same?
    Yes the Serv# is both 12643636
    May 2015
    My Tool Room
    REV# the same?
    filutek's Avatar
    Silesia
    Did you make a 1:1 ECM clone?
    What was the reason for replacing the ECM?
    Does the odometer show dashes or mileage?
    Read old ECMs and purchased ECMs and BCMs,upload here.
  8. The Following User Says Thank You to filutek For This Useful Post:
    rtbdiagnostic (5th January, 2023)
    May 2015
    My Tool Room
    ECM burnt vehicle was jump started incorrectly odometer shows curent mileage it might be that my cloning was not done correctly
    I will try again and report
  10. #9
    alex_r_2001's Avatar
    New Jersey ,, USA
    I have cloned lots of those with IOTERMINAL never had any problems..i never had any need to use sps, 100% clone and start no need to do anything else.. did you clone eeprom and flash?? I have some backups from a couple of E78 ecu in case you need...
    Check all your fuses maybe missing 12volt backup on ecm . Provide vin and I can post wiring diagram if you need.
    Solidarity with Ukraine
  11. The Following User Says Thank You to alex_r_2001 For This Useful Post:
    rtbdiagnostic (9th January, 2023)
  12. #10
    May 2015
    My Tool Room
    Issue was cloning done right this time car Ok now
