Results 1 to 15 of 15
    p1et's Avatar
    Oct 2013
    Default Renault Clio IV unlock/renew key card
    Which tool is reliable with unlocking these? Need tested 100% solution, not answers this and this because you saw it on the coverage list.
    Mar 2018
    UK
    Quote Originally Posted by p1et View Post
    I never had success tried KD XH and Barracuda - The card is unlocked but won't be programmed to the car
  3. The Following User Says Thank You to Manta1600 For This Useful Post:
    mikajna (6th January, 2023)
    p1et's Avatar
    Oct 2013
    So we can add to the list Miraclone, card just stay locked after unlocking.
    P&D's Avatar
    KDX2 unlocks them if your on about
    Genuine Part Number: 285971998R (handsfree) / 285974100R (non hands free)
    They read 4A ?
    Mar 2018
    UK
    Quote Originally Posted by P&D View Post
    KDX2 unlocks them if you on about
    They read 4A ?
    The question is can you program after that this card - All tools that I used unlock them but the card can't be programed
    I had thread about this 2 years ago and some one wrote that RET or something like this can program them but the Smart Pro can't IMO
    lion0304's Avatar
    Oct 2014
    Clio 4 handfree unlock with Keytool max and reprog iM508 succes for me. All functions work as needed.
    Use model: 285971998R for this Handfree.
  8. The Following 2 Users Say Thank You to lion0304 For This Useful Post:
    godfathertwo (6th January, 2023), Manta1600 (6th January, 2023)
  9. #7
    If you have autel km100 , try it, it might work
  10. #8
    mikajna's Avatar
    Mar 2015
    I've try with hexprog, but car not accept it, state was unlocked and frequency was ok, but car wont accept it.
  11. #9
    EU
    I unlock these card with Barracuda and KD-X2 but only tool that can programme cards on clio IV is RET ,even new cards I can only programme with RET
    I try AVDI and X300 DP but card is accepted only with RET
    I think that when You press Read card in RET it write something to card and that is why it work
    so most time I use AVDI to unlock HFM and after that programme card with RET
    HTH
  12. #10
    Oct 2017
    EU
    Quote Originally Posted by davorOS View Post
    HTH
    Last i unlock the card with vvdi mini and also with Avdi programmer. 2 different keys!
    only with programming with Avdi dont works. On the screen you see finish but key don’t works.
    the same key is accept by RET.
    When I help you
    PUSH on +THANKS and REP or
  13. #11
    newone's Avatar
    Oct 2016
    i have unlocked with key tool and program with k518
  14. The Following User Says Thank You to newone For This Useful Post:
    p1et (7th January, 2023)
  15. #12
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by newone View Post
    Key tool max? Mini key tool can do this also?
    This found out to be very interesting thread. Personally I will make job using aftermarket cards but I have couple OEM second hand so I thought to reuse them.
  16. #13
    newone's Avatar
    Oct 2016
    i have done it with old key tool,read hfm and programmed with k518 as akl,worked straight away
  17. #14
    Feb 2020
    Hi.
    I confirm that is possible to renew Clio IV cards, nokeyless and keyless with MK3 renew tool cheap chinese copy. But you must carefully open (cut) keycard to connect to board, and then glue it together. After that is card ready to code to car.
  18. #15
    Greece
    i use the first vvdi key tool. work 100%
  19. The Following User Says Thank You to kleidaras For This Useful Post:
    p1et (19th January, 2023)
